kak111
ARM Cortex M3 and Cortex M0 Development Tools
CooCox CoIDE
CoIDE is a new, free and highly-integrated software development environment for ARM cortex M3 and M0 based microcontrollers,
which includes all the tools necessary to develop high-quality software solutions in a timely and cost effective manner.
It integrates CoBuilder and CoDebugger for simplicity and ease of use.
CooCox CoOS
CooCox CoOS is an embedded real-time multi-task OS specially for ARM Cortex M series.
CooCox Colink
CooCox Colink is a small ARM Cortex M3 JTAG hardware debugging probe. It directly supports CoIDE and CoFlash,
and integrates seamlessly into IAR Embedded Workbench and Keil RealView MDK.
CooCox Colink is open, you can Do It Yourself.
CoLinkEx
CooCox CoLinkEx is a hardware debugging adapter which supports SW debugging and supports both ARM Cortex M3 and
Cortex M0 devices, it supports debugging in CooCox software and Keil Realview MDK.
CooCox CoLinkEx is open, you can Do It Yourself
CooCox CoFlash
CooCox CoFlash is a stand-alone Cortex M3 & Cortex M0 Flash Programming software for PCs running Microsoft Windows.
CoFlash has an intuitive user interface with a traditional Windows graphical user interface (GUI), and a command line mode as well.
CoFlash requires a CoLink. It is able to work with most common Cortex-M3 MCUs.
Users can define his own algorithm to support more flash devices, regardless of internal or external flash.
CooCox CoSmart
CooCox CoSmart is an intelligent pin configuration and code generation tool.
It provides pin multiplexing settings configuration, pin setting conflicts detection, effective code generation and
I/O cell characteristics specification.
CooCox CoAssistant
CooCox CoAssistant is a register assistant which could be used conveniently on line. It is specially supplied for
ARM Cortex M3 and Cortex M0 embedded hardware and software development engineers.
It could be used to develop chips for chip developers and be used as chip manual for chip users.
COX
COX is the definition of a group of interface function, contained in COX.h.
It defines the functional access functions of MCU’s common peripherals, such as IIC, SPI, UART, etc.
Free and open ARM Cortex M3 and Cortex M0 embedded development tools
CooCox CoIDE
CooCox CoOS
CooCox Colink
CoLinkEx
CooCox CoFlash
CooCox CoSmart
CooCox CoAssistant
COX
