Fractal Quad 2.4 Ghz
zlatkoMM
Full Member level 5
Full Member level 5
Croatia
Hi to all...!:)
Because i like to design antennas i have decided to present here my new
design of fractal variation of curtain quad wifi antenna for 2.4 GHz.
Main advantage over curtain quad as i see will be in small dimensions of this antenna.
Would love to see it mounted and the performance test. =)
Yes antenna work very good.
It is packed into small plastic case with aluminium foil as reflector.
Distance between antenna - reflectror is 30mm.
I have made version without balun transformer but work ok.
Sorry i dont have made any testing with software-
do you can recommend me some good freeware program for antena testing?
,,, look here .... **broken link removed** you can choose!
,,,or try this...http://www.petr-lorenz.com/emgine/
https://www.netstumbler.com/
,,,this it is work...**broken link removed**
,,,ok,ok,ok...it's good netstumbler!!!!!!
