FPGA to CortexM3 problems
dave3891
Newbie level 3
Newbie level 3
I have a FPGA pulse generator design that is connected to a STM32 board with SPI and I am having a strange problem with sending / receiving data.
The basic operation is that I send a quantity of pulses to the FPGA and then a frequency to pulse them at. The FPGA then counts them down as it pulses and I can read the remaining quantity back any time.
Sending the data seems to work as planned, but the receiving is quite strange.
I setup a test data send with the following:
// Set outgoing bytes
always @(posedge clk) begin
	if(SSEL_startmessage) begin
		sendTest <= 123456789;
		sendmem[0] <= sendTest[31:24];
		sendmem[1] <= sendTest[23:16];
		sendmem[2] <= sendTest[15:8];
		sendmem[3] <= sendTest[7:0];
		end
end
And then read it back on the M3 with this code:
  for ( i = 0; i < 4; i++ )
	  // Data out
	  while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET);
	  SPI_I2S_SendData(SPI1, src_addr[i]);
	  // Data in
	  while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == RESET);
	  inBuff[i] = SPI_I2S_ReceiveData(SPI1);
	  for(delay=0; delay<SPIDELAY; delay++);
  GPIO_WriteBit(GPIOC, GPIO_Pin_6, 1); // Set SSEL pin high
  remaining |= (inBuff[0] << 24);
  remaining |= (inBuff[1] << 16);
  remaining |= (inBuff[2] << 8);
  remaining |= (inBuff[3]);
  return remaining;
When I do this it returns the 123456789 as expected.
But if I send to a register and read it back, it comes back in a strange order. eg:
If I send 200 (hex 00 00 00 C8) it comes back as 3368550400 (C8 C8 00 00)
If I send 123 (00 00 00 7B) it comes back as 2071658496 (7B 7B 00 00)
But the numbers that I send appear to operate the FPGA as expected.
Here is the receive code on the FPGA:
	if(SSEL_endmessage) begin
		// Read the first byte for the command
		// 0x01 = position command
		// 0x02 = Velocity command
		if (mem[0] == 1) begin
			xcmd <= {mem[1], mem[2], mem[3], mem[4]};
			ycmd <= {mem[5], mem[6], mem[7], mem[8]};
			zcmd <= {mem[9], mem[10], mem[11], mem[12]};
			load <= 1;
		end
		else if(mem[0] == 2) begin
			frequency <= {mem[1], mem[2], mem[3]};
			loadFreq <= 1;
		end
	end
And here is the code that sends it from the M3:
uint32_t xCommand = 123;
uint32_t yCommand = 200;
uint32_t zCommand = 200;
src_addr[0] = 1; //0x01 for command 0x02 for velocity
src_addr[1] = xCommand >> 24; src_addr[2] = xCommand >> 16; src_addr[3] = xCommand >> 8; src_addr[4] = xCommand;
src_addr[5] = yCommand >> 24; src_addr[6] = yCommand >> 16; src_addr[7] = yCommand >> 8; src_addr[8] = yCommand;
src_addr[9] = zCommand >> 24; src_addr[10] = zCommand >> 16; src_addr[11] = zCommand >> 8; src_addr[12] = zCommand;
SPISend((uint8_t *)src_addr, 13);
I am really lost with why the static set number from the FPGA sends correctly but reading back a previously send number that operates the FPGA as expected, does not read properly.
Any ideas would be appreciated.
Thanks
Dave
		end
end
	  // Data out
	  // Data in
  return remaining;
			load <= 1;
		end
			loadFreq <= 1;
		end
	end
Thanks
Dave
it is hard to figure out the problems from those snippest you put.
from what its look like - it seem like the fpga doesn't send any data back i.e doesn't return the send_mem ,
but it's just my hipotesis, based on those snipest, and the information you supplied.
the best thing in this cases of course, is to put a logic/scope/chipescope/signal tap and just trigger the spi lines and see what's happen.
I have checked the SPI lines and like I said, when I set it to the static value (123456789) that comes through perfectly.
Its when I read a previously sent value, it comes back but not in the correct order ("7B 7B 00 00" instead of "00 00 00 7B") So the number is there its just losing order or endianness somehow/somewhere
Thanks
Dave
Thanks
Dave
mabee you can post entire verilog spi code ?
Here is the SPI code (most of the SPI section came from fpga4fun.com)
module LPCFPGA(input clk,
					input SCK,
					input MOSI,
					input SSEL,
					output MISO,
					output reg step,
// SPI Registers
reg [7:0] mem [0:24];
reg [7:0] memCount;
reg [7:0] sendmem [0:4];
reg [2:0] bitcnt;
reg byte_received;
reg [7:0] byte_data_received;
// New registers
reg [31:0] xcmd;
reg [31:0] ycmd;
reg [31:0] zcmd;
reg [24:0] accum;
reg load, loadFreq;
// sync SCK to the FPGA clock using a 3-bits shift register
reg [2:0] SCKr;  always @(posedge clk) SCKr <= {SCKr[1:0], SCK};
wire SCK_risingedge = (SCKr[2:1]==2'b01);
wire SCK_fallingedge = (SCKr[2:1]==2'b10);
reg [2:0] SSELr;  always @(posedge clk) SSELr <= {SSELr[1:0], SSEL};
wire SSEL_active = ~SSELr[1];
wire SSEL_startmessage = (SSELr[2:1]==2'b10);
wire SSEL_endmessage = (SSELr[2:1]==2'b01);
reg [1:0] MOSIr;  always @(posedge clk) MOSIr <= {MOSIr[0], MOSI};
wire MOSI_data = MOSIr[1];
begin
  if(~SSEL_active)
    bitcnt <= 3'b000;
  else
  if(SCK_risingedge)
  begin
    bitcnt <= bitcnt + 3'b001;
    byte_data_received <= {byte_data_received[6:0], MOSI_data};
  end
end
always @(posedge clk) byte_received <= SSEL_active && SCK_risingedge && (bitcnt==3'b111);
		memCount <= 0;
	end
	else if(byte_received) begin
		mem[memCount] <= byte_data_received;
		memCount <= memCount + 1;
	end
end
		cnt <= 0;
		if(cnt < 3)
			cnt <= cnt+1;
		end
end
reg [7:0] byte_data_sent;
reg [7:0] cnt;
if(SSEL_active)
begin
    byte_data_sent <= sendmem[cnt];
  else
  if(SCK_fallingedge)
  begin
    if(bitcnt==3'b000)
    else
      byte_data_sent <= {byte_data_sent[6:0], 1'b0};
  end
end
assign MISO = byte_data_sent[7];
		sendmem[0] <= xcmd[31:24];
		sendmem[1] <= xcmd[23:16];
		sendmem[2] <= xcmd[15:8];
		sendmem[3] <= xcmd[7:0];
		end
end
// Process the package once message is complete
			load <= 1;
		end
			loadFreq <= 1;
		end
	end
	else begin
		loadFreq <= 0;
		load <= 0;
	end
end
// Run the accumulator based on the sent frequency
	if(loadFreq)
		accum <= 0;
	else
		accum <= accum + frequency;
end
reg thing_dly;
wire pulsy;
assign pulsy = accum[24] & ~thing_dly;
always @(posedge clk) thing_dly <= accum[24];
endmodule
