library ieee;
use ieee.std_logic_1164.all;
entity Main is
port (
--T_test: out std_logic;
P_UART_TX: out std_logic
end Main;
architecture behav of Main is
signal S_MainClock : STD_LOGIC :='0';
signal S_UARTClock : STD_LOGIC :='0';
signal S_TX_DATA : std_logic_vector(15 downto 0) := X"AB7C";
signal S_UART_READY: std_logic;
signal S_UART_RESET: std_logic :='1';
COMPONENT Clock
-- synthesis translate_on
port (stdby : in std_logic;
osc_int: out std_logic;
p_UartClock : out std_logic;
P_resetclock : out std_logic
END COMPONENT;
COMPONENT UART
PORT(
P_UARTDATA: out std_logic ;
UARTREADY: out std_logic;
P_CLK: in std_logic;
P_Data: in std_logic_vector(15 downto 0);
P_Reset: in std_logic;
P_STDBY: in std_logic
END COMPONENT;
begin
CompClock: Clock
PORT MAP(
STDBY => '0',
osc_int => S_MainClock,
p_UartClock => S_UARTClock,
P_resetclock => S_UART_RESET
CompUART: UART
PORT MAP(
P_UARTDATA => P_UART_TX,
UARTREADY => S_UART_READY,
P_CLK => S_UARTClock,
P_Data => S_TX_DATA,
P_Reset => S_UART_READY,--S_UART_RESET,
P_STDBY => '0'
--T_TEST <= S_UARTClock;
end behav;
library ieee;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
-- For Main Clock --
library machXO3l;
use machXO3l.all;
entity Clock is
end Clock;
architecture Clock_behav of Clock is
signal S_InternalClock : std_logic;
signal S_mainClock : std_logic;
signal S_UARTClock : std_logic;
signal S_PLLEN : std_logic;
signal CLK_DIV : std_logic_vector (13 downto 0) := (others => '0');
COMPONENT OSCH
-- synthesis translate_off
GENERIC (NOM_FREQ: string := "133.00");
PORT (STDBY : IN std_logic;
OSC : OUT std_logic
END COMPONENT;
attribute NOM_FREQ : string;
attribute NOM_FREQ of Clock : label is "133.00";
COMPONENT ClkPll
PORT (CLKI : IN std_logic;
ENCLKOP : IN std_logic;
CLKOP : OUT std_logic;
ENCLKOS : IN std_logic;
CLKOS : OUT std_logic
END COMPONENT;
begin
Clock: OSCH
GENERIC MAP( NOM_FREQ =>"133.00" )
PORT MAP ( STDBY => '0',
OSC => S_InternalClock
CompPll: ClkPll
Port Map( CLKI => S_InternalClock,
ENCLKOP => S_PLLEN,
CLKOP => S_UARTClock,
CLKOS => S_mainClock,
ENCLKOS => '1'
-- clock divider
process (S_UARTClock)
begin
if (rising_edge(S_UARTClock)) then
CLK_DIV <= CLK_DIV + '1';
end if;
end process;
S_PLLEN <= not stdby;
osc_int <= S_mainClock;
p_UartClock <= S_UARTClock;
P_resetclock <= CLK_DIV(13);
end Clock_behav;
barry, you need to see an optometrist :wink:, there is definitely a pattern but it's not a 67% duty cycle. We have low going pulses of equal duration with alternating high pulses of 1x and 2x of the low pulse width.What you've shown looks a very stable 1MHz clock with a 67% duty cycle.
Agree completely, that weird clock behaviour needs to be addressed first. Though I can't make heads or tails from the description of the design, nor understand anything since the design is buried behind a bunch of schematic based blocks that the tools want you to use to permanently lock you into that FPGA companies products.Once you get the clock working, start debugging the rest of the system.
update, I put a simple clock divider written in vhdl and the clock signal is mostly at 125kHz, with sometimes with a one 10us pulse. I'm going to look at the signal generated by the internal oscillator and see how it is behaving (the logic analyzer i have isn't fast enough for 113MHz)
Why are you using a logic analyzer, use a oscilloscope to look at the clock and if you expect there are issues with glitches, then use a scope with a persistence mode and see if there is anything wrong with the clock.
Makes me wonder if you were having a sampling problem using a logic analyzer to look at the clock instead of a proper scope.
From the netlist Analyzer that diamond generates, I believe that it is (all but the port P_STDBY of UART.vhd, it is declared but it isn't being used in the code)Is it properly terminated?
I don't know how to check that. The only resource the I actually used to learn how to use a fpga is the book Free Range VHDL, so there is a lot I don't understand and am still trying to figure out.Are the voltage levels correct? Are your timing constraints corr
it an off the shelf fpgaI think you are confusing pin-mapping with termination. Just because the signal shows up in the netlist doesn't mean it's terminated properly on the PCB. Are you using a custom board, or an off-the-shelf one?
I'll try to find this constraint file, but I have no idea where diamond keeps it, i looked at some of the timing analysis view tool but I dont think thats it. out of curiosity is it the spreadsheet view?If you use an oscilloscope, you will be able to see what your voltage levels are. And your constraint file will define what voltage levels (e.g. LVCMOS, LVTTL, etc.) the the FPGA is expecting. Timing constraints are also defined in a constraint file: something as simple as declaring the maximum clock frequency.
WARNING - synthesis: c:/users/daniel/desktop/projects/fpga/lattice/rs232/main.vhd(14): using initial value "1010101101111100" for s_tx_data since it is never assigned. VHDL-1303
WARNING - synthesis: c:/users/daniel/desktop/projects/fpga/lattice/rs232/main.vhd(9): replacing existing netlist Main(behav). VHDL-1205
Top module name (VHDL): Main
Loading NGL library 'C:/lscc/diamond/3.10_x64/ispfpga/xo2c00a/data/xo2alib.ngl'...
Loading NGL library 'C:/lscc/diamond/3.10_x64/ispfpga/xo2c00/data/xo2clib.ngl'...
Loading NGL library 'C:/lscc/diamond/3.10_x64/ispfpga/mg5g00/data/mg5glib.ngl'...
Loading NGL library 'C:/lscc/diamond/3.10_x64/ispfpga/or5g00/data/orc5glib.ngl'...
Loading device for application map from file 'xo3c6900.nph' in environment: C:/lscc/diamond/3.10_x64/ispfpga.
Package Status: Final Version 1.16.
Top-level module name = Main.
WARNING - synthesis: Initial value found on net T_test will be ignored due to unrecognized driver type
WARNING - synthesis: Initial value found on net r_TX_DV will be ignored due to unrecognized driver type
WARNING - synthesis: Initial value found on net o_SendData will be ignored due to unrecognized driver type
GSR instance connected to net \CompUART/CompDataSelect/i_reset_N_73.
WARNING - synthesis: Initial value found on instance \CompUART/CompDataSelect/s_counter_i0 will be ignored.
WARNING - synthesis: Initial value found on instance \CompUART/CompDataSelect/s_counter_i1 will be ignored.
WARNING - synthesis: Initial value found on instance \CompUART/CompDataSelect/s_counter_i2_reset will be ignored.
WARNING - synthesis: Initial value found on instance \CompUART/CompDataSelect/s_counter_2__N_70_I_0_reset will be ignored.
WARNING - synthesis: mRegister \CompUART/CompDataSelect/s_counter_2__N_70_I_0_reset is stuck at Zero
Duplicate register/latch removal. \CompUART/CompRS232/r_TX_Data_i4 is a one-to-one match with \CompUART/CompRS232/r_TX_Data_i6.
Applying 200.000000 MHz constraint to all clocks
WARNING - synthesis: No user .sdc file.
Results of NGD DRC are available in Main_drc.log.
All blocks are expanded and NGD expansion is successful.
Writing NGD file UART_impl1.ngd.
#BLOCK ASYNCPATHS;
#BLOCK RESETPATHS;
#FREQUENCY 200.000000 MHz;
BLOCK RESETPATHS ;
BLOCK ASYNCPATHS ;
LOCATE COMP "P_UART_TX" SITE "B5" ;
LOCATE COMP "T_test" SITE "B4" ;
Power Calculator - Report
Lattice Diamond Version 3.10.3.144 - Power Calculator
Copyright (C) 1992-2018 Lattice Semiconductor Corporation.
All Rights Reserved.
Power Model Information
Format Revision : 1.11, 1.03, 1.00, 1.02 - Software
Values Revision : 1.16, 1.08, 1.00, 1.05 - Software
Power Model Status : Final Version 1.16
Design and Device Details
Power Project Name : Untitled - User/Default/NCD Provided
Design Name : Main - User/Default/NCD Provided
Family : MachXO3L - User/Default/NCD Provided
Device : LCMXO3L-6900C - User/Default/NCD Provided
Package : CABGA256 - User/Default/NCD Provided
Operating : Commercial - User/Default/NCD Provided
Part Number : LCMXO3L-6900C-5BG256C - User/Default/NCD Provided
Process Type : Typical - User/Default/NCD Provided
Power Supplies
Vccio 3.3 : 3.300 V - User/Default/NCD Provided
Vccio 2.5 : 2.500 V - User/Default/NCD Provided
Vccio 1.8 : 1.800 V - User/Default/NCD Provided
Vccio 1.5 : 1.500 V - User/Default/NCD Provided
Vccio 1.2 : 1.200 V - User/Default/NCD Provided
Vcc : 3.300 V - User/Default/NCD Provided
Power Summary
Power Est. Design Vccio 3.3 : 0.000000 W
Power Est. Design Vccio 2.5 : 0.000011 W
Power Est. Design Vccio 1.8 : 0.000000 W
Power Est. Design Vccio 1.5 : 0.000000 W
Power Est. Design Vccio 1.2 : 0.000000 W
Power Est. Design Vcc : 0.101461 W
Total Power Est. Design : 0.101472 W
Icc Summary
Icc Est. Design Vccio 3.3 : 0.000000 A
Icc Est. Design Vccio 2.5 : 0.000004 A
Icc Est. Design Vccio 1.8 : 0.000000 A
Icc Est. Design Vccio 1.5 : 0.000000 A
Icc Est. Design Vccio 1.2 : 0.000000 A
Icc Est. Design Vcc : 0.030746 A
Total Icc Est. Design : 0.030750 A
IO Bank Summary
IO Bank Used : 2
Peak Startup
VCC : 0.0790 A
VCCIO : 0.0170 A
Thermal Summary
Board Selection : Medium Board
Heat Sink : No Heat Sink
Air Flow : 200 LFM
Ambient Temperature : 25 C
Effective Theta-JA : 18.85
Junction Temperature : 26.91 C
Maximum Safe Ambient : 81.77 C
Utilization Details
Logic
LUTs Used : 43
Dist. RAM Slices Used : 0
Ripple Slices Used : 4
Registers Used : 36
Dynamic Power (W) : 0.000000
Static Power (W) : 0.014010
Total Power (W) : 0.014010
Clocks
PCLKs Used : 9
SCLKs Used : 7
ECLKs Used : 0
Static Power (W) : 0.000528
Total Power (W) : 0.000528
I/O
I/O Used : 6
Static Power (W) : 0.000404
Total Power (W) : 0.000404
Block RAM
EBR Blocks Used : 0
Static Power (W) : 0.000524
Total Power (W) : 0.000524
PLL
PLL Used : 1
Static Power (W) : 0.021228
Total Power (W) : 0.021228
DQSDLL
DQSDLL Used : 0
Static Power (W) : 0.000017
Total Power (W) : 0.000017
DLLDEL
DLLDEL Used : 0
Static Power (W) : 0.000015
Total Power (W) : 0.000015
EFB
I2C1 Used : 0
I2C2 Used : 0
SPI Used : 0
TC Used : 0
WISHBONE Used : 0
Other
CLKDIV Used : 0
CIBTEST Used : 0
MCLK Used : 1
SED Used : 0
Dynamic Power (W) : 0.036611
Static Power (W) : 0.028119
Total Power (W) : 0.064730
The second block specify timing; the third specifies pin location, but only for two pins. You seem to be missing a bunch of constraints.
thanks, but aren't constraints more for optimization? either way I reading lattice's Lattice Diamond Tutorial and Lattice Synthesis Engine forRead the user manual about how to specify constraints.
