FPGA jumping logic
I am new to FPGA programming and I am using HDL Verilog (Using Vivado) to generate a game similar to geometry dash.
I've written a code such that whilst the button is being pressed the block jumps up and down in the same x position. Once the button is released, the floor changes to 32 pixels above the initial floor and this stays as the new floor position.
However, this was not what was trying to achieve. My code makes it so the floor position is dictated by whether the button is being pressed or not. I was trying to make it such that when the button is pressed the block keeps jumping and if a certain condition is met (i.e. The floor position changes) then the block starts jumping from the new floor position and if the button is released the block rests on the new floor position (exactly like the platforming in geometry dash).
I can see that I need to make the floor position and button press independent but I have no idea how to do it. Any guidance is appreciated
My code referring to the jumping logic:
module jumping#(parameter
    FLR_POS = 11'd696,
    BLK_HGT = 11'd32,
    INL_BLK_X = 11'd300,
    INL_BLK_Y = FLR_POS - BLK_HGT,
    SPD = 11'd32,
    ACCEL = 11'd2)(
    //input pix_clk,
    input game_clk,
    input [4:0] btn,
    output [10:0] blkpos_x,
    output [10:0] blkpos_y
    reg [10:0] floor = 11'd696;
    reg [10:0] blkpos_x_r = 11'd300;
    reg [10:0] blkpos_y_r = 11'd664;
    reg jump_state;
    reg [10:0] spd_y = 11'd32;
    reg [10:0] acc_y = 11'd2;
    always@(posedge game_clk) begin
        if(btn[1]) begin
            jump_state <= 1;
        end
        else if ((btn[1]==0) && (blkpos_y_r + BLK_HGT >= (floor - 11'd32))) begin
            jump_state <= 0;
        end
    end
        if(btn[0]) begin
            blkpos_x_r <= 11'd503;
            blkpos_y_r <= FLR_POS - BLK_HGT;
        end
        else if(jump_state == 1) begin
           blkpos_y_r <= blkpos_y_r - spd_y;
           spd_y <= spd_y - acc_y;
           if (spd_y == -SPD - acc_y) begin
               spd_y <= SPD;
               blkpos_y_r <= blkpos_y_r;
           end
           if (blkpos_y_r + BLK_HGT >= (FLR_POS - 11'd32)) begin
               floor <= floor - 11'd32;
           end
        end
        else if(jump_state == 0) begin
            spd_y = SPD;
            acc_y = ACCEL;
        end
    end
    assign blkpos_x = blkpos_x_r;
    assign blkpos_y = blkpos_y_r;
endmodule
Hello,
I don't understand why input [4:0] btn is 5-bit vector when you wolud like only have two states: pushed and not(pushed). The second question is that you have not the debouncer for button - in such case pushing buttons might generate sequence of states pushed and not pushed (joint oscilations). I don't see any interface to display state of game - the easiest is VGA - which one could implement using several resistors. And in such case you have to synchronise state of objects in game with displaying it on VGA monitor.
Best Regards
--- Updated ---
Hello,
Best Regards
BTW: if you want to have button position counter then you should have incrementation/decrementation of [4:0] btn vector when button is pushed (or maybe two buttons: left and right).
