This warning meas that you have enabled some remote solver in HFSS and the remote computer settings are not correct so if you need remote computation properly define the settings if not needed then disable this option. Anyways that is warning and it says that mentioned computer for remote computation is not available*Global - Messages
[warning] The application could not resolve the IP address of this machine: remote analysis and remote distributed analysis will not work.
This is error it means the defined port has material on both sides it clearly means that port definition is not correct as while defining ports always keep one thing in mind that PORTS are usually either Source or SINKHFSSDesign1 (DrivenTerminal)
[error] Port refinement, process hf3d error: Port 1 does not have a solved inside material on either side.
