folded cascode opamp for the bandgap
surianova
Advanced Member level 1
ASIA
hi!
is it good to use folded cascode opamp for the bandgap? bcoz it have more pair to match and more prone to mismatch and introduce input offset.
when we do the design of bandgap , we normally take the tcf and psrr and line specs into consideration ! we can get the high psrr using the folded-cas amp ,but it will also introduce some offset , improve the area factor can reduce the offset at some degree! when you think about what is the amp archi you want to choose ,maybe you should choose it according to your design spec , eg: the design power dissipation and the supply power!
we often choose folded-amplifier to design the bandgap, it's ok!
