hello
im trying to design flyback transformer with marty brown book formulas .
it has two formulas in CGS and MKS system as it says .
ive just put same values in these two and getting different results .
what im doing wrong?
sure i will appreciate that
kheyli mamnoon
Then good to know that ;-)yes i am
Question yourself ! would the flyback converter work if it was DC signal ? we break the switch before the inductor be saturated so now we can look into that , in another manner .are you sure that formula works fir this ?
i think thats for DC current and doesn't have dt effected.
but my problem is not actually about the inductance calculation .
its mostly about the Lgap and number of turns of an inductor .
can i find toroid gapped core online ?
i found at some stores but their gap size were not defined .
Hi againoh!
i was confused with joules and watts at first .
theoretically if you consider the magnetic efficiency and overall efficiency around 100 percent it is right but for now it is absolutely wrong ! you looking for a clue ? i give you a rule of thumb ! add 15 or 20 percent to this ratio ! 0.1(1+20/100) Okay ?Iinave=P/Vin=0.1A
