The auxilliary winding is in intimate contact with the secondary winding as it is wound on the same core, therfore any load current variation on the secondary output will cause a proportional voltage drop, which will reflect through the transformer and cause a corresponding voltage drop in the auxilliary winding which is sensed by the voltage feedback input of the IC and a rapid correction will be made to the PWM switching waveform to compensate. The overall system pulse current is monitored by the current sense resistor in the source of the switching FET which again will sense the increased load and allow for it. The turns ratio of the auxilliary winding to the primary winding will generate the correct voltage to run the IC, this will be proportional to the main secondary output winding as they have the same turns per volt ratio, so a 10% drop on the secondary will create a 10% drop in the auxilliary winding, which will be compensated for by the IC as explained above.
I hope that makes sense and is not to much of an over-simplification.
Best regards,
Bob.
