baileychic
Advanced Member level 3
My flow meter code is not working properly. I have to multiply the count of the TMR1 register by 2 to get correct value. Why is it ?
This is my code. PIC18F26K22 is running at XT 4 MHz.
This is the screenshot of simulation.
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 #include "float2ascii.h" // LCD module connections sbit LCD_RS at LATB4_bit; sbit LCD_EN at LATB5_bit; sbit LCD_D4 at LATB0_bit; sbit LCD_D5 at LATB1_bit; sbit LCD_D6 at LATB2_bit; sbit LCD_D7 at LATB3_bit; sbit LCD_RS_Direction at TRISB4_bit; sbit LCD_EN_Direction at TRISB5_bit; sbit LCD_D4_Direction at TRISB0_bit; sbit LCD_D5_Direction at TRISB1_bit; sbit LCD_D6_Direction at TRISB2_bit; sbit LCD_D7_Direction at TRISB3_bit; // End LCD module connections // strings const code char txt1[] = " Flow Meter "; const code char txt2[] = "dL/ds: "; char txt[32]; typedef struct { unsigned long pulses_per_sec; unsigned char one_sec_delay_counter; unsigned char one_second_delay_count; double liters_per_sec; double scaling_factor; } FLOW_METER_TYPE; FLOW_METER_TYPE my_flow_meter; //Timer0 //Prescaler 1:8; TMR0 Preload = 3036; Actual Interrupt Time : 500 ms void InitTimer0() { T0CON = 0x82; TMR0H = 0x0B; TMR0L = 0xDC; GIE_bit = 1; TMR0IE_bit = 1; } void Interrupt(){ if((TMR0IE_bit) && (TMR0IF_bit)) { TMR0IF_bit = 0; TMR0H = 0x0B; TMR0L = 0xDC; //Enter your code here if(++my_flow_meter.one_sec_delay_counter >= my_flow_meter.one_second_delay_count) { TMR1ON_bit = 0; my_flow_meter.one_sec_delay_counter = 0; TMR0IE_bit = 0; } } if((TMR1IE_bit) && (TMR1IF_bit)) { TMR1IF_bit = 0; } } char *CopyConst2Ram(char * dest, const code char *src) { char *d; d = dest; for(;*dest++ = *src++;); return d; } void main(void) { CM1CON0 = 0x00; CM2CON0 = 0x00; ANSELA = 0x00; ANSELB = 0x00; ANSELC = 0x00; TRISA = 0x00; TRISB = 0x00; TRISC = 0x01; PORTA = 0x00; PORTB = 0x00; PORTC = 0x00; LATA = 0x00; LATB = 0x00; LATC = 0x00; Delay_ms(200); Lcd_Init(); Lcd_Cmd(_LCD_CURSOR_OFF); Lcd_Cmd(_LCD_CLEAR); //Lcd_Out(1,1,CopyConst2Ram(txt, txt1)); Lcd_Out(2,1,CopyConst2Ram(txt, txt2)); T1CON = 0b10000100; T1GCON = 0x00; my_flow_meter.scaling_factor = 1.70068e-4; PWM1_Init(588); PWM1_Set_Duty(127); PWM1_Start(); while (1) { TMR1H = 0; TMR1L = 0; InitTimer0(); TMR1ON_bit = 1; while(TMR1ON_bit); my_flow_meter.pulses_per_sec = (unsigned long)(((unsigned int)(TMR1H << 8) + TMR1L) * 2); my_flow_meter.liters_per_sec = (double)my_flow_meter.pulses_per_sec * my_flow_meter.scaling_factor; Float2Ascii(my_flow_meter.liters_per_sec, txt, 5); strcat(txt," "); Lcd_Out(2,8,txt); Float2Ascii((double)my_flow_meter.pulses_per_sec, txt, 2); strcat(txt," "); Lcd_Out(1,1,txt); } }
