hi,all
I am designing a floating bias class AB buffer, which is reference to Ron Hogervorst. But CL is only 10pF in his paper.Now, I have to keep a large Cl (such as 1uF) , this make the compesation rather critical.
Because large CL, the output pole will be gm/CL, this will be low frequency.The miller compasation will create a low frequency pole too.
At the 1st tapout, I deleted the miller cap, and bias the cascode to linear region to make the internal pole to high frequency.The output pole is the dominant pole.
The silicon result shows it will oscillate.
Have any of you ever design large cap load buffer before?
