dhakeparag81
Full Member level 2
hello there,
I wrote modbus application for pic81f87k22 cpu that support only integer value.
Might be you know that in float msb is signed 8 exponent and 23 mantisa i got that much of knowledge from documentation.
I want to write function in c that convert integer value to float and vice versa.
What is the procedure to convert float to integer?
Do you have any document on that or c code?
Please note that im not talking about type casting, because i want to transfer these data through modbus and other hand there may be any device which support modbus protocol with IEEE 754 for float.
