Mar 2, 2012 #1 E eng-a-hesham Junior Member level 2 Joined Oct 14, 2011 Messages 23 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,427 according to what should i select "flicker noise corner frequency" that should be achieved in my system blocks design ?!
Mar 2, 2012 #2 BigBoss Advanced Member level 6 Joined Nov 17, 2001 Messages 5,964 Helped 1,609 Reputation 3,225 Reaction score 1,593 Trophy points 1,393 Location Türkiye Activity points 35,841 Depending your active device...It may be few hundred Hz to few tenth MHz...
Mar 2, 2012 #3 B biff44 Advanced Member level 6 Joined Dec 24, 2004 Messages 5,047 Helped 1,376 Reputation 2,748 Reaction score 1,056 Trophy points 1,393 Location New England, USA Activity points 37,910 use 10 KHz to get started
Mar 2, 2012 #4 V vfone Advanced Member level 6 Joined Oct 10, 2001 Messages 5,709 Helped 1,616 Reputation 3,237 Reaction score 1,248 Trophy points 1,393 Activity points 36,264 As was stated, 1/f corner could be between hundreds of Hz and few MHz. 10kHz would be a lucky guess if is not mentioned the type of the active device used.
Mar 3, 2012 #5 E eng-a-hesham Junior Member level 2 Joined Oct 14, 2011 Messages 23 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,427 what do you mean by (type of active device) ?!? do you mean the technology used in design ??! or what !! and does it have any rule ,or it's just by experience !!
Mar 3, 2012 #6 V vfone Advanced Member level 6 Joined Oct 10, 2001 Messages 5,709 Helped 1,616 Reputation 3,237 Reaction score 1,248 Trophy points 1,393 Activity points 36,264 I mean, JFET, BJT, GaAs FET, CMOS, have totally different flicker noise corner.
Mar 3, 2012 #7 E eng-a-hesham Junior Member level 2 Joined Oct 14, 2011 Messages 23 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,427 ok , now i decided to use CMOS technology .. still don't know based on what should i specify flicker noise corner.
Mar 3, 2012 #8 V vfone Advanced Member level 6 Joined Oct 10, 2001 Messages 5,709 Helped 1,616 Reputation 3,237 Reaction score 1,248 Trophy points 1,393 Activity points 36,264 There are a lot of articles on the net or in dedicated books related to this issue, mainly for CMOS which is one of the most used process today. https://www.eecs.berkeley.edu/~hu/PUBLICATIONS/Hu_papers/Hu_CNF/HuC_CNF_231.pdf **broken link removed**
Mar 4, 2012 #9 E eng-a-hesham Junior Member level 2 Joined Oct 14, 2011 Messages 23 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,427 ok thanks
