Note: This feature currently requires accessing the site using the built-in Safari browser.
hrkhari said:Smaller aspect ratio with minimal gate length, L, ensures lower flicker noise.
Rgds
Syukri said:Vg = (k/(WL(Cox)f)
u see that there is an existance of WL? when uscale down a device, the size is smaller than before thus amplifying the Vg...
but this is not usually happen with scaling becasue the parameters used in new smaller technology is different from previous..the voltage supplied is far less than before and k is different...
Cox=εox/tox...when scaling is done, thikness is reduce and if same material is used than the oxide capacitance is increasing....
smaller gap of the gate channel and the top of the substarte encouraging flicker noise
hebu said:Syukri said:Vg = (k/(WL(Cox)f)
I can't relaize the last sentence "smaller gap of the gate channel and the top of the substarte encouraging flicker noise"
Smaller gap means the thickness of gate oxide?
So, overall the flicker noise is worsen in advanced process?
In general the circuit design (including choice of device types) determines nearly everything.Any layout skills can help to reduce 1/f noise?
Presumably we are looking at gate-referenced Voltage noise here? If so, this could apply to some processes and bias conditions; however, there are too many variables.For the same size, flicker noise of the device in 0.18um is smaller than that in 0.35um due to increased Cox. But if to use minimal length device(for constant W/L in different process), it is another story, maybe smaller maybe worse.
welcom correct if anything wrong..
