Flash memory from Microchip problem SST25VF080B
Kareem101
Newbie level 2
Trying to use SST25VF080B to store some important data, but I am finding the hardest time to get useful info from data sheet,
The Datasheet didnt specify how do define the addresses that i will write in or read from ??
If anyone used this chip before, The help would be very much appreciated
Thanks
Its there in datasheet.
It's a SPI communication so no need to set any device address in communication.
Use CE# pin for chip selection and use above mentioned code for data transfer and erase.
Thanks,
Jolly Jacob
24 bit Address for memory is MSB 1st then address auto increment begins (AAI) .Default is byte mode address.
Does the datasheet not make sense?
  • Prior to any write operation, the Write-Enable (WREN) instruction must be executed.
  • Initiate the AAI Word Program instruction by executing an 8-bit command, ADH, followed by address bits [A23-A0 ].
  • Following the addresses, two bytes of data are input sequentially, each one from MSB (Bit 7) to LSB (Bit 0).
  • The first byte of data (D0) is programmed into the initial address [A23 -A1 ] with A0 =0, the second byte of Data (D1) is programmed into the initial address [A23 -A1 ] with A0 =1.
  • CE# must be driven high before executing the AAI Word Program instruction.
  • Check the BUSY status before entering the next valid command.
  • Once the device indicates it is no longer busy, data for the next two sequential addresses may be programmed, followed by the next two, and so on
