Flash memory access problem - please help
bobcat1
Hi
I'm trying to access AMD FLASH AM29f080B-90 memory and it's dosen't
work well :
1) access to flash is working from time to time e.g one time i can access and read the menufecture ID and on time I can't read it
2) Programing is the same
My logic analyzer show 100nS access pulse for Read Write and CS
I think the problem relay to access time - ?
thanks
bobi
Hi bobcat1,
How do you access this flash? By a CPU? What type?
It could be possible that you have an address change during the WR/CS
pulse or a spike on your VCC line. Do you have decoupling capacitors?
Bye
Yes I do Access the flash using a philips XA cpu
Yes I do Access the flash using a philips XA cpu oprating @ 20 Mhz
To access the Flash I'm using an address decoder programed on cypress
cpld
Yes i do have decupling cup's on every chip vcc -> gnd .
bobi
flash access
hello,
can you read any data? do you have two flash devices in parallel to reach 16bit bus-with. then you have to be care for the adresses you send to the flash (you have to double the adresses).
if you have an logic analyzer, check wether the cpu sends the correct unlock cycles (if you want to read device id or during programing).
greetings,
hqqh
Hi bobcat1,
Check (with oscilloscope or logic-analyzer) if the setup and holdtimes
are met. Probably there is a problem with the propagation-time inside
your address-decoder.
Bye
I'm using an 8 bit wide data bus and a single flash chip
I'm using an 8 bit wide data bus and a single flash chip in the system
I also have an external uart 16c552 and extenal ram and it's working
very well , e.g. Accessing the RAM & the UART work without ant system
error's
the problem is only with the flash memory
bobi
You should disable all of any interrupts during Flash memory access (read and write).
