Flash memory 93lc512 data ???
alzhrani
Newbie level 6
Hi every one,
Could any one help me, I have flash memory 93lc512 and I went to download a data on it
I have programmer and it support 93lc512,, how can I download data (lets say a table of Ascii file)
One of my friends says to me you should convert that file to HEX file and download the file to memory by programmer.
Isn’t there any configuration?????
Did the data (first element will be stored in first register and second will be in second,, and so on …….)
Any suggestion please to solve that problem???
Best regard
alzhrani
You can use any microcontroller assembler and convert a table to HEX file.
For example, download ASM51 from:
Create a file with ASCII table.
Here is an example [file: test1.txt]
DB 32h, 30h, 31h, 30h
END
Then run ASM51.EXE and it will create a hex file that looks like the following:
:040000003230313039
:00000001FF
which you can download to your memory.
DrWho
Thank you DRWhoF for your answer,, could you please help me for these questions
Firstly, what did you mean by DB & END is it necessary to put it there, and it is general technique for all memories?
What about registers,, is the register will be like this after programming
32h will be in register 1
30h will be in register 2
31h will be in register 3
30h will be in register 4
Could you please suggest me another program to make HEX file for my table?
Because that program (ASM51) doesn’t work with me…
Thank you again
could anyone hellllp me please ???????
