fixed point multiplication using verilog
siva_7517
Full Member level 2
Full Member level 2
verilog fixed point
In fixed-point multiplication, we should add an extended sign bit in the multiplication process . Example below:
1.110 -0.25 B
X 0.110 0.75 C
0000
111110
11110
0000
11110100 -0.1875 A
I have try to do a verilog as below:
assign A = B * C
But i dont have an idea on how to do a extended bit in verilog. Hope can help me on this.
Thank in advance.
You can use the concatenation operator.
assign A = {4{B[3]}, B} * {4{C[3]}, C};
verilog multiplication
Is this equation is include with the extra sign bit while doing the multiplication?
assign A = {4{B[3]}, B} * {4{C[3]}, C};Hi,
signed multiplication verilog
Yes, it is 4-bit signed times 4-bit signed and result is 8-bit signed.
fixed point verilog
-----------------1.110 @@@@@@@ -0.25 B
--------------X 0.110 @@@@@@ 0.75 C
---------------- 0000
------------111110------------------->extended sign bit
------------11110--------------------->extended sign bit
----------+0000
----------11110100 @@@@@@@@-0.1875 A
i understand with concept of increase the output bit........but when we do a fixed point multiplication there is extra sign bit in inserted before the adding is done. I have difficulty on how to intepret this in verilog.thanx
