ADGAN
Full Member level 5
- Joined
- Oct 9, 2013
- Messages
- 295
- Helped
- 4
- Reputation
- 8
- Reaction score
- 4
- Trophy points
- 18
- Activity points
- 1,837
Hi! I wrote a program to count the pulses coming from an energy measurement IC. But I observed that the first pulse is not counted both in Proteus and in hardware. So I'm assuming that something must be wrong in the software. I'm using the timer1 for this task of PIC16F887. What I suspect is the T1CON. What is the mistake I have done?
void main()
ANSEL = 0;
ANSELH = 0;
TRISA = 0;
C1ON_bit = 0; // Disable comparators
C2ON_bit = 0;
PORTA.RA0 = 1;
TRISB = 0;
PORTB = 0;
PORTC = 0;
TRISC = 0x99;
INTCON = 0xC0;
PIE1.TMR1IE = 1;
PIR1.TMR1IF = 0;
T1CON = 0x03;
TMR1L = 0;
TMR1H = 0;
I2C1_Init(100000);
Lcd_Init();
Delay_ms(100); // Delay 100ms
Lcd_Cmd(_LCD_CURSOR_OFF);
Lcd_Cmd(_LCD_CLEAR);
while(1){
pulses = (count*65536)+ (TMR1H<<8 | TMR1L);
LongToStr(pulses,txt);
Lcd_out(1,9,txt);
