narayani
Full Member level 2
- Joined
- Aug 15, 2014
- Messages
- 137
- Helped
- 0
- Reputation
- 0
- Reaction score
- 1
- Trophy points
- 1,298
- Activity points
- 2,364
Dear Sir,
In the ADS, pHEMT ATF54143 transistor linear model is not available, hence I have taken the S-parameter file from the Avago technology and I have taken the DATA ITEM from the ADS component palette.The S2P data item drag and place it on the schematic and shown the path of S-parameter file of ATF54143 transistor to S2P data item.
Now I am in confusion, how to find out the Gate (G),Source(S),and Drain(D) of the pHEMT transistor S2P Data item.
Which is gate,source,and drain in the S2P Data item, when data item is attached ATF54143 transistor S-parameter file.
Can you clarify it.
Can you clarify it.
