[SOLVED] find the error of this program of ofdm coding
gaurav22
Newbie level 2
Newbie level 2
% No.of Carriers: 512
% coding used: Convolutional coding
% Single frame size: 768 bits
% Total no. of Frames: 800
% Modulation: 128-QAM
% No. of Pilots: 32
% Cylic Extension: 25%(16)
close all
clear all
clc
% Generating and coding data
t_data=randint(80000,1)';
x=1;
si=1; %for BER rows
for d=1:800;
data=t_data(x:x+799);
x=x+800;
k=3;
n=6;
s1=size(data,2);  % Size of input matrix
j=s1/k;
% Convolutionally encoding data
constlen=7;
codegen = [171 133];    % Polynomial
trellis = poly2trellis(constlen, codegen);
codedata = convenc(data, trellis);
%Interleaving coded data
s2=size(codedata,2);
j=s2/4;
matrix=reshape(codedata,j,4);
intlvddata = matintrlv(matrix',2,2)'; % Interleave.
intlvddata=intlvddata';
% Binary to decimal conversion
dec=bi2de(intlvddata','left-msb');
%128-QAM Modulation
M=128;
y = qammod(dec,M);
% scatterplot(y);
% Pilot insertion
lendata=length(y);
pilt=3+3j;
nofpits=4;
k=1;
for i=(1:13:52)
    pilt_data1(i)=pilt;
    for j=(i+1:i+12);
        pilt_data1(j)=y(k);
        k=k+1;
    end
end
pilt_data1=pilt_data1';   % size of pilt_data =52
pilt_data(1:52)=pilt_data1(1:52);    % upsizing to 512
pilt_data(13:512)=pilt_data1(1:52);   % upsizing to 512
for i=1:52
    pilt_data(i+6)=pilt_data1(i);
end
% IFFT
ifft_sig=ifft(pilt_data',512);
% Adding Cyclic Extension
cext_data=zeros(80,1);
cext_data(1:128)=ifft_sig(49:512);
for i=1:800
    cext_data(i+128)=ifft_sig(i);
end
% Channel
 % SNR
 o=1;
for snr=0:2:50
ofdm_sig=awgn(cext_data,snr,'measured'); % Adding white Gaussian Noise
% figure;
% index=1:80;
% plot(index,cext_data,'b',index,ofdm_sig,'r'); %plot both signals
% legend('Original Signal to be Transmitted','Signal with AWGN');
%                   RECEIVER
%Removing Cyclic Extension
for i=1:512
    rxed_sig(i)=ofdm_sig(i+128);
end
% FFT
ff_sig=fft(rxed_sig,512);
% Pilot Synch%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%
for i=1:52
    synched_sig1(i)=ff_sig(i+6);
end
k=1;
for i=(1:13:52)
    for j=(i+1:i+12);
        synched_sig(k)=synched_sig1(j);
        k=k+1;
    end
end
% scatterplot(synched_sig)
% Demodulation
dem_data= qamdemod(synched_sig,128);
% Decimal to binary conversion
bin=de2bi(dem_data','left-msb');
bin=bin';
% De-Interleaving
deintlvddata = matdeintrlv(bin,2,2); % De-Interleave
deintlvddata=deintlvddata';
deintlvddata=deintlvddata(:)';
%Decoding data
n=6;
k=3;
decodedata =vitdec(deintlvddata,trellis,5,'trunc','hard');  % decoding datausing veterbi decoder
rxed_data=decodedata;
% Calculating BER
rxed_data=rxed_data(:)';
errors=0;
c=xor(data,rxed_data);
errors=nnz(c);
% for i=1:length(data)
%     if rxed_data(i)~=data(i);
%         errors=errors+1;
%     end
% end
BER(si,o)=errors/length(data);
o=o+1;
 end % SNR loop ends here
 si=si+1;
end % main data loop
% Time averaging for optimum results
for col=1:25;        %%%change if SNR loop Changed
    ber(1,col)=0;
for row=1:800;
        ber(1,col)=ber(1,col)+BER(row,col);
    end
end
ber=ber./800;
figure
i=0:2:48;
semilogy(i,ber);
title('BER vs SNR');
ylabel('BER');
xlabel('SNR (dB)');
grid on
