find signal propagation path in sequential circuits in Design Compiler
Amir Yazdanbakhsh
Newbie level 5
Newbie level 5
I am using Design Compiler to synthesize a sequential design. I want to find all the cells (including combinational and sequential) from a given input to an output. I know that I can use "all_fanin". But the problem is that it stops at the clock of the sequential elements. I am wondering if there is a command for that.
Thanks
Why don't you do a report_timing from the startpoint till the endpoint?
