As the secondary has a load of 3 K this will be reflected back to the primary, add to this the extra 1K, gives a total impedance of 4 K. makes no difference where the secondary is earthed.
Frank
I wonder where the problem comes from.
As stated (no interwindings capacitance respectively no asymmetry in winding capacitances) it has no solution. Not "the tricky part", just no way.
There's no "bus" or other distributed load in the posted schematic. Seems like you are withholding essential information.The Problem is a Practical One And one needs to Find Short of Shield on Secondary Side(Because then the bus becomes Suceptible to EMI with a Shield Shorted to a Conducting Wire) from Primary Side...
A mathematical solution starts with a complete equivalent circuit of the circuit with all parasitic elements. With your assumptions given up to now (ideal transformer), there's no solution at all.We are here trying to find a Mathematical Solution to Problem instead of Practical Values...
The Transformer Winding Ratio Lp:Ls is 1:1 (Isolation Transformer) and is an ideal one so negligible inter-winding capacitance.We are here trying to find a Mathematical Solution to Problem instead of Practical Values...
I wonder how many different answers we'll still get to the same question.Since it is a Practical Question You can Assume parasitic Capacitances,Resistances(of Practical Values) But the Circuit is Symmetrical One as chuckey Points out
What I fail to understand is how to find if SHIELD is shorted to Point A or Point B Without Access to Secondary Transformer Coil...
We Have Access to Primary Winding,Shield and are provided with Signal Generator
Connect the two primary terminals together and measure the capacitance from that point to the shield. That capacitance will most likely be substantially different if there is a short from shield to secondary.
