foxbrain
Full Member level 2
- Joined
- Feb 1, 2010
- Messages
- 142
- Helped
- 5
- Reputation
- 10
- Reaction score
- 4
- Trophy points
- 1,298
- Location
- Damas
- Activity points
- 2,322
Where this sound is coming from ? from an amplifier ? where is the input signal ? from a CD player ? or MP3 player ? more information is required .hi
do u know how can i filter this wav file from the noise sound? i prefer using the wavelet theory
thanks
Ok , you need to analyze spectrum of this music and then understand what is frequency or BW of those noises . and then design a filter function for that BW . and then you'll get success ! that's all .i don't know ....
my professor gave this file to filter it as a project using matlab
i know that but how?
do u know how can i do it?you can also use the wavelet
what is the instruction for this?and how can i know the noise from it?take 22 ms or 15 ms of small audio frame analyze
352kbpswhat is ur signal sampling frequency ?
noise with audioin x3 whether it is total noise or noise with audio ? u can check by wavplay.
yesin ur hole wave file x3 is the only noise patch ?
here is the picture attacheduse command fft in command window and take the abs() and plot
