heythem2008
Newbie level 6
- Joined
- Jul 9, 2008
- Messages
- 14
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- sherbrooke, canada
- Activity points
- 1,373
well... if you want - just try;heythem2008 said:but i don't use the wrfull i want just use the wrempty
and rdempty
add to your simulator 'rdclk' and 'wrclk' of the fifo and you will see whereheythem2008 said:Morover i think the problem is due to the read clock
your schematic is wrong from logical point of view, so it's not good for anyheythem2008 said:does my schematic allow me to get my purpose?
if not can you help me to obtain a good one.
it's not so important what is your data source and receiver,heythem2008 said:ok, i want use a fifo to save the samples obtained from
my 8bits adc/.../
very simple solution assuming write and read clock is the same:heythem said:/.../cut off with 128 samples my adc/.../
for the reception i need when the fifo is full to start reading
forgot it ...the problem is in the delay of receiving
