shyamsundar
Newbie level 2
HI EVERYBODY I M TRYING TO WRITE A CODE FOR FIFO AND GOT THIS SAMPLE FROM THE NET. NOW I HAD WRITTEN A TESTBENCH FOR THIS AND IN THE FUNCTIONAL SIMULATION I M UNABLE TO GET THE READ AND WRITE POINTERS UPDATED. CAN ANYONE HELP SOLVE THIS PROBLEM??
module fifo2(clk, rst, fr, fw, data, out);
parameter fifo_width=8, fifo_depth=16, ptr_width=4;
input clk, rst, fr, fw;
input [fifo_width-1:0]data;
output [fifo_width-1:0]out;
wire full, empty;
integer j;
reg [fifo_width-1:0]out;
reg [ptr_width-1:0]wp;
reg [ptr_width-1:0]rp;
reg [fifo_width-1:0]stack[fifo_depth-1:0];
reg [ptr_width-1:0]fifo_count;
If this is a write access, put the data on the
input bus into the location pointed to by the
fifo write pointer
always @ (posedge clk)
begin
if (fw) begin
stack[wp] <= data;
end
end
If this is a read get the data that is in
the location pointed to by the read pointer
and put it onto the output bus
begin
if (fr) begin
out <= stack[rp];
end
end
Increment the write pointer on every write and
the read pointer on every read
if (rst)
wp <= 0;
else
wp <= (fw) ? wp + 1 : wp;
if (rst)
rp <= 0;
else
rp <= (fr) ? rp + 1 : rp;
The fifo counter increment on every write and
decrement on every read
begin
if (rst) begin
fifo_count <= 0;
end
else begin
case ({fw,fr})
2'b00: fifo_count <= fifo_count;
2'b01: fifo_count <= (fifo_count == 0) ? fifo_depth:fifo_count - 1;
2'b10: fifo_count <= (fifo_count == fifo_depth) ? 0:fifo_count + 1;
2'b11: fifo_count <= fifo_count;
endcase
end
end
//assign fifo_hf = (fifo_count >= 4);
//assign fifo_he = (fifo_count <= 4);
assign empty = (fifo_count == 0);
assign full = (fifo_count >= fifo_depth);
endmodule //of fifo
//-----------------------------TEST BENCH-----------------------------------------------
module fifo_tb;
reg clk, rst, fr, fw;
reg [fifo_width-1:0]data;
wire [fifo_width-1:0]out;
wire full, empty;
integer h;
reg [ptr_width-1:0]wp=0,mp=0;
reg [ptr_width-1:0]rp=0;
reg [fifo_width-1:0]mem[fifo_depth-1:0];
fifo2 f1(clk, rst, fr, fw, data, out);
initial
begin
clk = 1'b1;
rst = 1'b1;
$readmemb("stimuli_fifo.txt", mem);
h=$fopen("result_fifo.txt");
#20 rst = 1'b0;
end
always
#5 clk = ~clk;
initial
begin
#30 fw = 1'b1;
#30 fr = 1'b1;
#120 fw = 1'b0;
#10 fr = 1'b0;
end
always @(posedge clk)
begin
if(fw)
begin
data = mem[mp];
mp = mp+1; // INCREMENT mem INDEX
if(full)
$display(" FIFO OVERFLOW");
else if(empty)
$display("FIFO UNDERFLOW");
end
end
begin
$display("out = %d, data = %d", out, data);
$display("fifo_count = %d", fifo_count);
$fdisplay(h,"out = %d", out);
end
endmodule [/quote][/code]
wire full, empty;
integer j;
fifo write pointer
begin
if (fw) begin
stack[wp] <= data;
end
end
begin
if (fr) begin
out <= stack[rp];
end
end
if (rst)
wp <= 0;
else
if (rst)
rp <= 0;
else
begin
if (rst) begin
fifo_count <= 0;
end
else begin
case ({fw,fr})
endcase
end
end
endmodule //of fifo
module fifo_tb;
wire full, empty;
integer h;
initial
begin
clk = 1'b1;
rst = 1'b1;
#20 rst = 1'b0;
end
always
#5 clk = ~clk;
initial
begin
#30 fw = 1'b1;
#30 fr = 1'b1;
#120 fw = 1'b0;
#10 fr = 1'b0;
end
begin
if(fw)
begin
data = mem[mp];
if(full)
else if(empty)
end
end
begin
end
