aoshater
Newbie level 6
fifo gate level
We are working on a project where we want to implement a SERDES. Of course it is mostly analog circuit design, meaning, each block is treated transistor level and analysed and layout will be manual.
There is a FIFO block though which uses two clocks, one from the reference clock from the INPUT data stream. The second is the internally generated clock from the CDR loop. Question is, from my reading, FIFO block looks like a pure DIGITAL block, so what is the methodology that you suggest in its design?
My collegues are using the analog design steps:
1) circuits
2) schematic simulation
3) layout and parasitic extraction and so on.
But i am assuming for the FIFO block it would be a digital design methodology. Can you give me a summary of the design steps. Thank you.
1) circuits
