FIFO circular queue buffer issue
manasic
Junior Member level 1
hello friends;
I am implementing a circular queue fifo buffer: I am having a issue that when a simulation signal read enable is given my waves stop appearing. I think its some issue with my implementation. can anyone help: following is my FIFO code and the test bench is attached along with:
Code VHDL - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.numeric_std.all;
use IEEE.std_logic_unsigned.all;
entity FIFO_buffer is
port ( clk: in std_logic;
       rst : in std_logic;        -- system clock;
       re : in std_logic;        -- read enable;
       we : in std_logic;        -- write enable;
   datain : in std_logic_vector(7 downto 0);                                                  -- datainput;
   dataout : out std_logic_vector(7 downto 0);                                                -- dataoutput;
      req  : out std_logic;
      empt : inout std_logic;        -- buffer empty status;
      full : inout std_logic);        -- buffer full status;
end FIFO_buffer;
architecture behavior of FIFO_buffer is
   type buffertype is array (0 to 15) of std_logic_vector(7 downto 0);                        -- buffer depth;
   signal depth: buffertype := (others => (others => '0'));                                   --contents of buffer at the time of initialisation
   signal rdptr :  unsigned(3 downto 0) := "0000";
   signal weptr :  unsigned(3 downto 0) := "0000";                                            -- read and write pointer
   constant zero : unsigned (1 downto 0):= "00";
   constant one : unsigned (1 downto 0):= "01";
   begin
--________________________________________________________________________________________________________________________________________________
process(clk,rst,re,we,rdptr,weptr,full,empt)                                               -- process to write or read data and increment pointers
begin
if rst='1' then
rdptr <= (others => '0');
weptr <= (others => '0');
empt <='1';
full <='0';
end if;
if ((re = '1') or (full = '1')) then
    rdptr <= rdptr + one;
    dataout <= depth(to_integer(rdptr));
end if;
if ((clk' event and clk = '1') and ((we = '1') or (empt = '1'))) then
      depth(to_integer(weptr)) <= datain;
      weptr <= weptr + one;
end if;
if (weptr + one = rdptr) then
    full <='1';
else
    full <='0';
end if ;
if (rdptr = weptr ) then
    empt <='1';
else
    empt <='0';
end if ;
end process;
--____________________________________________________________________________________________________________________________________________________
requestgeneration:process(full,empt,rdptr)                                                          -- process to generate request to arbiter
begin
if ((full = '1') or (empt = '0') or (rdptr > "0010")) then
    req <= '1';
elsif ((empt = '1') or (rdptr < "0010")) then
    req <= '0';
end if;
end process;
end behavior;
[ /syntax ]
test bench:
[syntax=vhdl]
library IEEE;
entity test_fifo is
end entity;
architecture behavior of test_fifo is
component FIFO_buffer is
   port (
       clk : in std_logic;
      full : inout std_logic;
--weptr_stat : inout std_logic_vector;
--rdptr_stat : inout std_logic_vector;
      req  : out std_logic);        -- buffer full status;
end component;
signal clk_t : std_logic := '0';
signal rst_t : std_logic := '0';
signal re_t  : std_logic := '0';
signal we_t  : std_logic := '0';
signal datain_t : std_logic_vector(7 downto 0) := "00000000";
begin
fifo1: FIFO_buffer port map (clk_t,rst_t,re_t,we_t,datain_t);
inputdata:process(we_t)
          begin
          if (we_t = '1') then
              datain_t <= "00001111";
          end if;
          end process;
systemclock:process
            begin
            clk_t <= '1';
            wait for 1 ns;
            clk_t <= '0';
            wait for 1 ns;
        end process;
systemreset:process
            begin
            rst_t <= '0';
            wait for 100 ns;
            rst_t <= '1';
            wait for 1 ns;
            end process;
readenab:  process
          begin
            re_t <= '0';
            wait for 76 ns;
            re_t <= '1';
            wait for 76 ns;
          end process;
writeenab :  process
          begin
            we_t <= '1';
            wait for 5 ns;
            we_t <= '0';
            wait for 5 ns;
        end process;
sumulation:process
  begin
   wait for 1000 ns;
   assert false report "end simulation" severity failure;
  end process;
end behavior;
[ /syntax ]
Thanks
Manasi
When re is '1', the rdptr is incremented. But the process is also sensitive to rdptr, meaning it keeps incrementing in 0 time in an infinite loop (hence why the simulation freeze).
You are not following the proper coding templates. Counters must be inside a clocked part of a process. It is also bad practice to "and" anything with a clock, it should be inside the clock if branch.
All that should be in the senstivity list for a clocked process is (clk, reset)
Thanks;
see its an evident difference between a newbie and an expert. Thanks , it helped me a lot and it worked.
Manasi
Reactions: sai685
    sai685
