field oxide thickness ?
mojtaba_led
Newbie level 6
Newbie level 6
hi
how can i calculate field oxide thickness of a NMOS?
I think it depends on voltage of drain so we can say :
V= Qox/Cox
Cox= (ε_0 ε_sio2 )/d
e.g. if Vd = 5 v & Qox = 1×10^11×q
thus
d= (5×8.85×10^(-14 )×3.9)/(5×10^(11 )×1.6×10^(-19 ) ))=2.16*10^(-5 )= .216 μm
what's your idea?
is it right ?
is it right ?
No, I don't think so. First: the drain capacitance isn't just a field oxide cap but is composed of several different caps, mainly the bulk-drain-cap Cbd (a junction cap), and the gate-drain-overlap-cap Cgd (a gate oxide cap), s. e.g. Allen/Holberg Chap. 3 .
Only the drain access routing contributes some thick oxide cap, but this usually isn't a dominant part of the total drain capacitance.
Of course the field oxide thickness also depends on the process size.
Here, the area A is missing in the numerator.
Qox = 1×10^11×q
Where from did you get the factor 1×10^11 ? Must be a unit-less number of charge carriers.
Field oxide thickness is not really related to FET working
voltage in my experience. The gate oxide is enough to
stand off Vds(max), Vgs(max) and field oxides I've seen
are over 10X thicker.
Part of this is because you don't really want the lowest
level of interconnect (routing poly) to contribute as much
capacitive loading as gate poly does, for no useful upside.
thank you so much .
Excuse me i just want to calculate field oxide thickness approximately . overall is there a formula (approximately) for calculating ?
so can we say the field oxide capacitance is sum of Cbd & Cgd in series connection?
yes, that's true.but i found it from "Microelectronics: Processing and Device Design" page 261.
it's just an example from "Microelectronics: Processing and Device Design" for the surface state density .
so can we say e.g.if gate oxide thickness be .01 μm then field oxides thickness ≈ .1 μm ?
my friend told me the way of calculating the field oxides thickness is similar to threshold voltage way calculating !
Yes: if you know the threshold voltage of field oxide MOSFETS (s. below).
Of course not: as I told you above, both mentioned caps are not field oxide capacitances! And their series connection doesn't make sense at all!
Even books/papers sometimes have typos. Always better check!
Ok, but you have so many assumptions in your calculation - how should that fit to any particular process size?
Sure you can, but I doubt it would fit.
Yes, if you know its field oxide threshold voltage and the correct surface state density of this particular process.
I think it's much easier to find the field oxide thickness if you know (or tell) for which process (size) you want it!
thanks.
Excuse me, is it your mean : Vt= ∅_MS - Qox/Cox - Qd/Cox + 2∅_f
yes,i agree with you and checked it, but i think it's true , because this is for calculating capacitance that unit of it is [F/CM^2] not [F] , on the other hand this capacitance is the oxide capacitance density per unit area so A=1.
actually, i don't know and i didn't think about it ,perhaps because i wanted just to solve my problem!
oh,I'm very tired!
1. how can i obtain field oxide threshold voltage ? what dose it depend on ?
2. here in my problem surface state density = 1×10^11 1/cm^2
that sounds great!
actually, i want design a NMOS inverter with these features : Picture14.png
so i must calculate the field oxide thickness for around the inverter .
hi
Vt= ∅_(MS )- Qox/Cox+ Qd/(Cox )+2∅_f
consider : vt = maximum voltge that may be placed on field oxide = 5v
and , Na = 1×10^15 1/cm^3 --> ∅_(MS ) = -.86 v
Qox=1×10^11×q=8×10^(-8 ) c/cm^2
∅_f=KT/q ln⁡(Na/ni)=0.0259ln⁡(1×10^15/1.5×10^10 )=0.288 v
Qd=2√(ε_0 ε_(si ) qNa∅_f )=2√(8.85×10^(-14 )×11.95×10^(15 )×1.6×10^(-19 )×.288)
Vt= -.86- (8×10^(-8 ))/Cox+ (1.39×10^(-8 ))/(Cox )+2×0.288=5
Cox= (1.39×10^(-8 )- 8×1^(-8 ) )/(5+ 0.86- 2×0.288)= -1.25×10^(-8 ) F/cm^2
--> d= (5×8.85×10^(-14 )×3.9)/(1.25×10^(-8 ) )=1.38×10^(-4 ) cm=1.38μm
--> field oxide thickness = 1.38μm .
is it right ?
Hi mojtaba,
1. the maximum voltage that may be placed on field oxide is not the threshold voltage of a field oxide MOSFET !
Even if your above calculations were correct (I didn't check them), you'd start from a wrong premise.
2. What for do you need the field oxide thickness at all? Your above shown inverter doesn't contain a field oxide transistor but a depletion transistor (I guess it's an NMOS), and such one uses the standard (thin) gate oxide - just a different channel implant. A field oxide NMOSFET would'nt work in this circuit configuration (would always be off).
____
BTW: A field oxide thickness of 1.38µm would be that of a very old process: a process size of 1.5 or 2µm had used such a thick field oxide, and such processes we had around 15..20 years ago.
thank you so much .
I think i need search and research much much more!
Excuse me , can you suggest me a good and update reference about ic fabriction ?
... can you suggest me a good and update reference about ic fabriction ?
Try the web sites of the "big" semiconductor fabs and foundries, like Intel, IBM, AMD, Samsung, TSMC, UMC, SMIC, ... and see which processes they offer.
