Hi, I agree with your comment. I am newbie in this field and don't have already an overview of these stuffs. I find some answers on internet but have no confidence whether it is right one or not. or it will lead me to unnecessary direction which might not be the right approach or it is incomplete/very basic information. That's why I wanted to get confirmation/another feasible approach from forum members who have a lot of experience in this field before I start.You repeatedly ask forum members to do simple research for you. This is why your posts are starting to get ignored by the more helpful members (I'll admit I was also going to ignore this post too...).
Thank you.Go to Altera's web site and search for the core. All your questions are answered in the documentation except for the price, which you will have to ask Altera's sales representatives about that or see if it shows up as a standard or purchased core in the megawizard.
It's clearly 2's complement...
Refer to the first sentence of post #2. All I did was open your link (in acrobat reader plugin) and Ctrl-F, format, Return, V,V,V,V,V...(the next button) and found that section. It wasn't hidden.
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity Learning_FFT is port ( clock : in std_logic; reset : in std_logic; source_valid : out std_logic; source_exp : out std_logic_vector(5 downto 0); source_real : out std_logic_vector(15 downto 0); source_imag : out std_logic_vector(15 downto 0) ); end Learning_FFT; architecture Behav of Learning_FFT is signal reset_n_sig : std_logic; signal address_sig : unsigned(8 downto 0); signal rden_sig : std_logic; signal x_n_sig : std_logic_vector(15 downto 0); signal wr_en : std_logic; signal wr_data : signed(15 downto 0); signal sink_valid_sig : std_logic; signal sink_sop_sig : std_logic; signal sink_eop_sig : std_logic; signal sink_ready_sig : std_logic; signal source_error_sig : std_logic_vector(1 downto 0); signal source_sop_sig : std_logic; signal source_eop_sig : std_logic; signal i : integer range 0 to 511:=0; type memory_type is array (0 to 511) of integer range -1024 to 1023; -- Sine wave having 512 value generated in Matlab having offset of 512. But during taking input in my Program, I subtracted 512 to make 0 offset. signal sine : memory_type :=(512, 571, 607, 607, 570, 511, 453, 417, 417, 454, 513, 572, 608, 607, 569, 510, 452, 416, 418, 455, 514, 573, 608, 606, 568, 509, 451, 416, 418, 456, 516, 574, 608, 606, 567, 508, 450, 416, 418, 457, 517, 575, 609, 605, 566, 506, 449, 415, 419, 458, 518, 576, 609, 605, 565, 505, 448, 415, 419, 459, 519, 577, 609, 604, 564, 504, 447, 415, 420, 460, 521, 578, 609, 604, 563, 503, 446, 414, 420, 461, 522, 579, 610, 603, 562, 502, 445, 414, 421, 462, 523, 579, 610, 603, 561, 500, 444, 414, 421, 463, 524, 580, 610, 602, 560, 499, 443, 414, 422, 465, 525, 581, 610, 602, 559, 498, 442, 413, 422, 466, 527, 582, 611, 601, 558, 497, 441, 413, 423, 467, 528, 583, 611, 601, 557, 495, 441, 413, 423, 468, 529, 584, 611, 600, 556, 494, 440, 413, 424, 469, 530, 585, 611, 600, 555, 493, 439, 413, 425, 470, 532, 586, 611, 599, 553, 492, 438, 413, 425, 471, 533, 586, 611, 598, 552, 491, 437, 412, 426, 472, 534, 587, 612, 598, 551, 489, 436, 412, 427, 473, 535, 588, 612, 597, 550, 488, 436, 412, 427, 475, 536, 589, 612, 597, 549, 487, 435, 412, 428, 476, 538, 590, 612, 596, 548, 486, 434, 412, 428, 477, 539, 590, 612, 595, 547, 485, 433, 412, 429, 478, 540, 591, 612, 594, 545, 484, 433, 412, 430, 479, 541, 592, 612, 594, 544, 482, 432, 412, 431, 480, 542, 593, 612, 593, 543, 481, 431, 412, 431, 482, 543, 593, 612, 592, 542, 480, 430, 412, 432, 483, 545, 594, 612, 592, 541, 479, 430, 412, 433, 484, 546, 595, 612, 591, 540, 478, 429, 412, 434, 485, 547, 595, 612, 590, 538, 477, 428, 412, 434, 486, 548, 596, 612, 589, 537, 475, 428, 412, 435, 487, 549, 597, 612, 589, 536, 474, 427, 412, 436, 489, 550, 597, 612, 588, 535, 473, 426, 412, 437, 490, 551, 598, 612, 587, 534, 472, 426, 413, 437, 491, 553, 599, 611, 586, 532, 471, 425, 413, 438, 492, 554, 599, 611, 585, 531, 470, 424, 413, 439, 493, 555, 600, 611, 584, 530, 469, 424, 413, 440, 495, 556, 600, 611, 584, 529, 468, 423, 413, 441, 496, 557, 601, 611, 583, 528, 466, 423, 413, 442, 497, 558, 602, 611, 582, 526, 465, 422, 414, 443, 498, 559, 602, 610, 581, 525, 464, 422, 414, 443, 499, 560, 603, 610, 580, 524, 463, 421, 414, 444, 501, 561, 603, 610, 579, 523, 462, 421, 414, 445, 502, 562, 604, 610, 578, 521, 461, 420, 414, 446, 503, 564, 604, 609, 577, 520, 460, 420, 415, 447, 504, 565, 605, 609, 576, 519, 459, 419, 415, 448, 506, 566, 605, 609, 575, 518, 458, 419, 415, 449, 507, 567, 605, 608, 574, 517, 457, 418, 416, 450, 508, 568, 606, 608, 574, 515, 456, 418, 416, 451, 509, 569, 606, 608, 573, 514, 455, 417, 416, 452, 511, 570, 607, 607, 572, 513, 454, 417, 417, 453, 512, 571, 607); component RAM is PORT ( address : IN STD_LOGIC_VECTOR (8 DOWNTO 0); clock : IN STD_LOGIC := '1'; data : IN STD_LOGIC_VECTOR (15 DOWNTO 0); rden : IN STD_LOGIC := '1'; wren : IN STD_LOGIC ; q : OUT STD_LOGIC_VECTOR (15 DOWNTO 0) ); end component RAM; component FFT_512 is PORT ( clk : IN STD_LOGIC; reset_n : IN STD_LOGIC; inverse : IN STD_LOGIC; sink_valid : IN STD_LOGIC; sink_sop : IN STD_LOGIC; sink_eop : IN STD_LOGIC; sink_real : IN STD_LOGIC_VECTOR (15 DOWNTO 0); sink_imag : IN STD_LOGIC_VECTOR (15 DOWNTO 0); sink_error : IN STD_LOGIC_VECTOR (1 DOWNTO 0); source_ready : IN STD_LOGIC; sink_ready : OUT STD_LOGIC; source_error : OUT STD_LOGIC_VECTOR (1 DOWNTO 0); source_sop : OUT STD_LOGIC; source_eop : OUT STD_LOGIC; source_valid : OUT STD_LOGIC; source_exp : OUT STD_LOGIC_VECTOR (5 DOWNTO 0); source_real : OUT STD_LOGIC_VECTOR (15 DOWNTO 0); source_imag : OUT STD_LOGIC_VECTOR (15 DOWNTO 0) ); end component FFT_512; begin -- Data has been written into RAM first Memory_inst : RAM port map ( address => std_logic_vector(address_sig), clock => clock, data => std_logic_vector(wr_data), --x"FFFF",--(others => '0'), rden => rden_sig, wren => wr_en, q => x_n_sig ); --Instantiating 512 Point FFT generated from IP Core. FFT Engine architecture: Quad Output and Number of --Parallel FFT engines: 1, I/O Data Flow: Streaming FFT_512_inst : FFT_512 port map ( clk => clock, reset_n => reset_n_sig, inverse => '0', sink_valid => sink_valid_sig, sink_sop => sink_sop_sig, sink_eop => sink_eop_sig, sink_real => x_n_sig, sink_imag => (others => '0'), sink_error => "00", source_ready => '1', sink_ready => sink_ready_sig, source_error => source_error_sig, source_sop => source_sop_sig, source_eop => source_eop_sig, source_valid => source_valid, source_exp => source_exp, source_real => source_real, source_imag => source_imag ); reset_n_sig <= not reset; process(clock) begin if rising_edge(clock) then if reset = '1' then rden_sig <= '0'; address_sig <= (others => '0'); elsif sink_ready_sig = '1' then rden_sig <= '1'; if rden_sig = '1' then address_sig <= address_sig + 1; end if; end if; end if; end process; process(clock) begin if rising_edge(clock) then if reset = '1' then sink_valid_sig <= '0'; sink_sop_sig <= '0'; sink_eop_sig <= '0'; elsif rden_sig = '1' then sink_valid_sig <= '1'; if address_sig(8 downto 0) = 0 then sink_sop_sig <= '1'; else sink_sop_sig <= '0'; end if; if address_sig(8 downto 0) = 511 then sink_eop_sig <= '1'; sink_valid_sig <= '0'; else sink_eop_sig <= '0'; end if; end if; end if; end process; process(clock) begin if rising_edge(clock) then if reset = '1' then wr_en <= '0'; wr_data <= (others => '0'); i <= 0; elsif sink_ready_sig = '1' then wr_en <= '1'; if wr_en = '1' then --wr_data <= to_signed((512 + sine(i)), 16); wr_data <= to_signed((sine(i) - 512), 16); -- Here I subtract 512 to make 0 offset. -- wr_data <= to_signed(512, 16); i <= i+ 1; if(i = 511) then i <= 0; end if; end if; end if; end if; end process; end Behav;
SOURCE - generate data
SINK - absorb data
Using the definition of each word it's pretty clear what is meant.
Which signals are you talking about, particularly?Then what is the use of sink_data and source_data signal which is there additionally as a another signal.
Obviously, your test signal is far from a clean sine. In so far, additional lines should be expected. It would be however helpful if you show the output signal, otherwise we have to guess or are required to setup a test bench ourselves.
Yes, the manual also answer your question how "sink_data" and "source_data" are related to the respective complex signal components, they include them.sink_data signal of page 3-18 of above link.
similarly, source_data signal of page 3-19 of above link.
Look sharp and realize that there's an option to generate a functional simulation model in the FFT core generator ("FFT compiler Megawizard").
The synthesizable IP is encrypted and can't be used for simulation, whatever license you have.
