ferrite bead as low pass filter search
levnu
Full Member level 2
Israel
Hi
i'm looking for a ferrite bead that will block 1-20 Mhz
frequancies and pass all lower ones
is it possible ?
can someone to advice me for one specific?
Best regards,
Arye
---------- Post added at 10:00 ---------- Previous post was at 09:33 ----------
block around 10 Mhz is good enough
Basically, you need a low pass filter to do the job.
thanks
but what i look for is one companent that do the filtering job
and not a lowpass filter as a circuit includes more companents
Arye
Hi, ferrite bead for low frequency application (below 20MHz) available on the market, do not have high impedance (few tens of Ohm) and therefore do not have advantages over other components normally used as filters (R-L-C).
hi,
you can just use a R-C filter,better work than ferrite. With the formula f=1/(2*3.14*R*C). one high pass & one low pass R-C circuit will help you to get your range of 1-20Mhz
the deign is there in the attachment
  • rc_filter.pdf
