jmreina
Newbie level 6
Ferranti Effect, where receiving end voltage is relatively larger than sending end, is more probable in transmission lines, when there is sudden drop of load. The sending end voltage is a bit higher than that with load at the receiving end. Will this phenomenon affect the armature of the generator (by means of change in bus voltage) located at the sending end bus of the transmission line?
