Feko Help
Hi guys
I need some help about my feko project. I want to simulate a cylinder with upper lid 3mm thickness aluminium, as u all know in feko a solid metallic sheet cannot be used , I defined a dielectic material with properties of aluminium? How about this ? i want advices og u peolpe how to simulate such problem
and if i use this dielctric then shoul i define face properties of the by metallic ? and if metallic face then what should be given in face thickness property?
2ndly how a threaded lid seam be introduced i used a spacing of .05mm?
thanks and waiting for early response as i always get solution to my problems at this forum.
waseem
