hoppaaa
Newbie level 3
Hello, Im working on a hfss project which i am supposed to make an antenna resonating L1 and L2 bands, I included the prototype sheet to my attachement.
The problem is in my s11 report only L2 band is working, which is via lower patch, and upper patch is having no effect.
I think the problem is with feeding but don't know why. I am using a coaxial probe feed, coax touching the first substrate from below, and the probe is connected to it going to top and touching upper patch, which is explained in the sheet im given.
But the result only showing antenna resonating at 1.2xx ghz' ish area.
Im pretty sure its about upper patch not working, because i tried removing the upper patch and still getting the same result.
I included my hfss file, a result screeny and the sheet to my attachment.
I'd appreciate any help, thanks for reading.
