I need to redraw it as a Series Shunt feedback amplifier, i.e. with the following topology:
Identifying the AC equivalent circuit seems to be easy: 12V and -12V become GND and current generator turns into an open circuit. However I have troubles identifying the amplifier net and the feedback net and the series shunt topology. Could you help me redrawing the circuit?
Thanks for the answer!
However I am not able to understand it... Feedback net should be a two port network.. and I can't see what are these ports.
Unfortunately my textbook (and I didn't have any luck searching on other books) doesn't cover the details about identifying the topology.
.......... Feedback net should be a two port network.. and I can't see what are these ports.
In the general case, a feedback net can have two ports but it doesn't have to be (and most feedback networks don't).
It this case the second port is the common (ground) connection.
