FCC Rule 15.245 Vs 15.249
tonyctsiu
Member level 1
Dear All,
I am planning to make a device which operates at 915Mhz frequency and trying to make it compliance to FCC rules. No frequency hopping.
I am not sure whether I should follow 15.245 or 15.247 as it seems there might be some contradictions:
In 15.245, it says the maximum field strength of fundamental is 500mV/M
while in 15.249, it says the maximum field strength of fundamental is just 50mV/M
Which rule should I follow?
Thanks in advance,
Tony
It's all in the FCC text. In a short, the 500 mV/m (about 19 dBm ERP) applies for wide band and frequency hopping transmitters.
A brief explanation under which prerequisites the higher field strength limits can be utilized is given in TI design note DN036
if it is a non-cw signal, you can time average to meet the specificaitons.
I'm no so familiar with interpretation of FCC regulations, but I read from §15.35, that averaging is only applied above 1000 MHz, while regular quasi peak measurement has to be used below 1000 MHz.
I had a 915 MHz system where it applied. I will try to find the rules.
Reactions: FvM
    FvM
