Deltatango
Member level 1
Trying to repair an old inverter of between 1Kw and 1.5Kw with a bank of 16 Mosfets working into 8 transformers to generate the HT on 3 x 47uF, I have got this section fixed though an IC marked CS2638 which drives them had me puzzled but seems to be a KA7500 type in disguise.
This section now works what seems OK as it can regulate then rest to maintain 300+ volts, a LM324 plays some parts in this inverter with slow start indicators and beeper.
As yet though I have not got its output end to work right, what seems to be a bank of H format Mosfets x 8, it did have an output of a modified sine wave but only seems to produce a narrow pulse in AC form (looks to be the peak pulse parts). What is lacking is the lower voltage wider pulses like rms section which I think should be from a second KA7500 but is only sending those narrow pulses.
The high voltage mosfets seem OK by basic measurement just need guidance and help to understand a bit better this section, found some help on your pages from a circuit included in a previous thread.
The only clue is some 1w resistors feeding rectifiers are cold and a 30v zener has only 20/25v across it so is lacking some drive force have measured parts in the output "front line" but nothing as yet, changed its three chips keep wondering if those mosfets are sick in some way that is not a short?
Thanks for any help.......
Deltatango :???:
Deltatango :???:
