Fault codes for a M266A motherboard
ljcox
Full Member level 5
Melbourne Australia
Does anyone know where I can find the fault codes for this MB.
When I switch the computer on, there is no bootup info on the screen & I can hear beeps.
I understand that these indicate hardware faults. But I don't know how to interpret the beeps I'm hearing.
Any assistance will be appreciated.
what beeps do you hear
long and short
forinstance
be be be be beep is a memory issue {4 short 1 long }
beeep be be be is a video card error {1 long 3 short}
you want to use google and look for
post error beep chart or similar
all pc machines use the same post beep codes
chances are its a video card error if you have no display
probably some dust in the video socket
or a ram not seated right or gubbed
be be be be be is a mpu error usualy regulation or gubbed caps
Computer Post / Beep codes
Thanks very much for that info & link.
That gives me a good starting point.
I'll let you know what I find.
I turned the PC on and there were 3 long beeps. Therefore a Keyboard issue.
So I plugged in the keyboard (a USB one) that I was using with it before the fault & heard the same beeps.
So I tried 3 different PS2 keyboards all with the same result.
I tried a PS2 & the USB one together - same result.
The LEDs on the keyboards don't flash as they normally do during bootup.
So I assume there is a hardware fault on the motherboard in the keyboard drive area.
So I'll remove the MB from the case & have a close look at that area.
However, as I don't have a circuit diagram, I don't like my chances of finding the fault - unless it is something obvious such as a dry joint.
I'll let you know the outcome.
Thanks for the input.
