process(clk,rst)
begin
if (rst='1') then
hashed_code<=(others =>'0');
else
if (clk'event and clk='1') then
--cur_state <= next_state;
hashed_code <= hmacsha384(IV,KEY,big_msg);
end if;
end if;
end process;
FATAL_ERROR: Vivado Simulator kernel has discovered an exceptional condition from which it cannot recover. Process will terminate. For technical support on this issue, please open a WebCase with this project attached at https://www.xilinx.com/support.
Time: 21050 ns Iteration: 0 Process: /QOSec/k1/m1/line__21
function HMACSHA384( IV : std_logic_vector (hashed_size-1 downto 0);-- salt
KEY : std_logic_vector;
message :std_logic_vector) -- message size
return std_logic_vector is
variable ipad : std_logic_vector (block_size - 1 downto 0) := ipad_generate(block_size);
variable opad : std_logic_vector (block_size - 1 downto 0) := opad_generate(block_size);
variable Si,So : std_logic_vector (block_size-1 downto 0);
variable kmessage1 : std_logic_vector((block_size + message'length)-1 downto 0);
variable kmessage2 : std_logic_vector ((hashed_size + block_size)-1 downto 0);
variable results1,results2: std_logic_vector((hashed_size -1 ) downto 0);
begin
Si := KEY xor ipad;
So := KEY xor opad;
kmessage1 := Si & message;
results1 := SHA384_HASHING(kmessage1,IV);
kmessage2 := So & results1;
results2 := SHA384_HASHING(kmessage2,IV);
return results2;
end HMACSHA384;
What version of Vivado is it? have you tried a newer version?
How big is "bigMessage"?
library IEEE;
use IEEE.STD_LOGIC_1164.all;
use IEEE.NUMERIC_STD.All;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
--///////////////////// PACKAGE HEADER STARTS HERE ///////////////////////////--
package HMACSHA384_ISMAIL is
-- Declare constants --
constant block_size : integer := 1024; --bits
constant word_size : integer := 64; --bits
constant rounds_number : integer := 80; --bits
constant hashed_size : integer := 384; --bits
constant length_bits : integer := 128; --bits
-- Declare functions needed --
-- MESSAGE PADDING FUNCTION
function message_padding (message: std_logic_vector)
return std_logic_vector;
-- GET MESSAGE BLOCK FUNCTION
function get_message_block (padded_message:std_logic_vector; block_number: integer)
-- GET MESSAGE BLOCKS COUNT
function get_message_blocks_count(padded_message:std_logic_vector)
return integer;
---- F FUNCTION
function F_FUNCTION (H : std_logic_vector (hashed_size - 1 downto 0);
message_block: std_logic_vector (block_size - 1 downto 0) )
-- F FUNCTION SUB FUNCTIONS
function T1 (f,c,d,e,w,k:std_logic_vector(word_size-1 downto 0))
function T2 (a,b,c:std_logic_vector(word_size-1 downto 0))
function Ch(c,d,e:std_logic_vector(word_size-1 downto 0))
function Maj(a,b,c:std_logic_vector(word_size-1 downto 0))
function SumA(a:std_logic_vector(word_size-1 downto 0))
function SumE(e:std_logic_vector(word_size-1 downto 0))
function Key(index: integer)
function ROTR(WORD:std_logic_vector(word_size-1 downto 0);ROUNDS:integer)
function SHR(WORD:std_logic_vector(word_size-1 downto 0);ROUNDS:integer)
--- W FUNCTIONS
function W_HASHING_1(word:std_logic_vector(word_size-1 downto 0))
function W_HASHING_2(word:std_logic_vector(word_size-1 downto 0))
function get_w_value (w_register: std_logic_vector (((rounds_number * word_size) - 1 )downto 0);
w_index: integer)
function generate_w_value(message_block:std_logic_vector(block_size-1 downto 0))
------ SHA384 HASHING FUNCTION
function SHA384_HASHING( message:std_logic_vector;
IV: std_logic_vector(hashed_size - 1 downto 0))
------ HMACSHA384 HASHING FUNCTION
------ HMACSHA384 SUB FUNCTIONS
function opad_generate (block_size: integer)
function ipad_generate (block_size: integer)
end HMACSHA384_ISMAIL;
--///////////////////// PACKAGE HEADER ENDS HERE /////////////////////////////--
--///////////////////// PACKAGE BODY STARTS HERE /////////////////////////////--
package body HMACSHA384_ISMAIL is --- START OF PACKAGE BODY
---- MESSAGE PADDING ----
variable mod_val: integer := (message'length) mod block_size; --504 mod 1024=504
variable padding_length : integer := ((block_size-129)+(block_size - mod_val));--=1415
variable padded_length : integer := (
message'length --504+(1+1415)+128=2048
+ (1 + padding_length)
+ length_bits
variable message_length: std_logic_vector(
(length_bits - 1) downto 0
) := (others=>'0');
variable padded_message: std_logic_vector (
(padded_length - 1) downto 0
) := (others => '0');
variable padding: std_logic_vector (
(padding_length) downto 0
begin
message_length := std_logic_vector(to_unsigned(message'length,length_bits)); --(504,128)
padding := "1" & std_logic_vector(to_unsigned(0,padding_length)); --(0,1415)
padded_message := message & padding & message_length; --504+1416+128=2048
return padded_message;
end message_padding;
---- GET MESSAGE BLOCK COUNT ----
return integer is
variable blocks_count : integer := (padded_message'length/block_size); --2048/1024=2
begin
return blocks_count;
end get_message_blocks_count;
---- GET MESSAGE BLOCK ----
variable blocks_count : integer := get_message_blocks_count(padded_message);
begin
return padded_message(((blocks_count - block_number) * block_size) - 1 downto --(2):()
(((blocks_count - (block_number + 1)) * block_size ))) ;
end get_message_block;
---- FUNCTION F ----
variable memory: std_logic_vector(5119 downto 0);
variable a,b,c,d,e,f,w,k : std_logic_vector (word_size-1 downto 0);
begin
a := H(383 downto 320);
b := H(319 downto 256);
c := H(255 downto 192);
d := H(191 downto 128);
e := H(127 downto 64);
f := H(63 downto 0);
memory := generate_w_value(message_block);
roundsloop : for i in 0 to (79) loop
-- init values
w := get_w_value(memory,i);
k := Key(i);
a := T1(f,c,d,e,w,k) + T2(a,b,c);
b := a;
c := b;
d := c;
e := d + T1(f,c,d,e,w,k);
f := e;
end loop ; -- roundsloop
return (a & b & c & d & e & f);
end F_FUNCTION;
---- GENERATE T1 VALUE ----
begin
return (f + Ch(c,d,e) + SumE(e) + w + k);
end T1;
---- GENERATE T2 VALUE ----
begin
return (SumA(a) + Maj(a,b,c));
end T2;
---- GENERATE Ch VALUE ----
begin
return ((c and d) xor ((not c) and e));
end Ch;
---- GENERATE Maj VALUE ----
begin
return ((a and b) xor (a and c) xor (b and c));
end Maj;
---- GENERATE SumA VALUE ----
variable tmp: std_logic_vector (word_size-1 downto 0);
begin
identifier : for i in 0 to hashed_size loop
tmp:= ROTR(a,28) xor ROTR(a,34) xor ROTR(a,39);
end loop ; -- identifier
return tmp;
end SumA;
---- GENERATE SumE VALUE ----
begin
identifier : for i in 1 to hashed_size loop
tmp:= ROTR(e,14) xor ROTR(e,18) xor ROTR(e,41);
return tmp;
end SumE;
---- GENERATE k VALUE ----
begin
return std_logic_vector(to_unsigned(index,word_size));
end Key;
---- GENERATE W VALUE ----
variable generated_word : std_logic_vector(word_size-1 downto 0);
variable WI1,WI2,WI3,WI4 : integer;
variable w_leg : integer := (rounds_number * word_size) - 1; --80*64
variable w_reg : std_logic_vector ( w_leg downto 0); --5120
begin
w_reg( w_leg downto 4096) := message_block; --was 4096 --=1024
wordGen : for t in 16 to (rounds_number - 1) loop
WI1 := t - 16 ; WI2 := t - 15 ;
WI3 := t - 7 ; WI4 := t - 2 ;
w_reg ( (64*(80-(t))) - 1 downto (64*(80-(t+1))) )
:= w_reg ( (64*(80-(WI1))) - 1 downto (64*(80-(WI1+1))) )
W_HASHING_1(
w_reg ( (64*(80-(WI2))) - 1 downto (64*(80-(WI2+1))) )
w_reg ( (64*(80-(WI3))) - 1 downto (64*(80-(WI3+1))) )
W_HASHING_2(
w_reg ( (64*(80-(WI4))) - 1 downto (64*(80-(WI4+1))) )
end loop ; -- wordGen
return w_reg;
end generate_w_value;
---- GET W VALUE ----
w_index: integer)
begin
--should not be more then 79
assert (w_index > (rounds_number - 1))
report "the value should not be more than 79"
severity warning;
return w_register(((word_size * (rounds_number-w_index)) - 1) downto
(word_size * (rounds_number-(w_index+1))));
end get_w_value;
---- W HASHING FUNCTIONS -----
-- FRIST W HASHING FUNCTION
variable hashedWord1 : std_logic_vector(word_size-1 downto 0);
begin
hash1looping : for i in 0 to hashed_size loop
hashedWord1 := ROTR(word,1) xor ROTR(word,8) xor SHR(word,7);
end loop ; -- hash1looping
return hashedWord1;
end W_HASHING_1;
-- SECOND W HASHING FUNCTION
variable hashedWord2 : std_logic_vector(word_size-1 downto 0);
begin
hash2looping : for i in 1 to hashed_size loop
hashedWord2 := ROTR(word,19) xor ROTR(word,61) xor SHR(word,6);
end loop ; -- hash2looping
return hashedWord2;
end W_HASHING_2;
---- ROTATE Function ----
variable ratatedWord: std_logic_vector(word_size-1 downto 0) := WORD;
begin
ROTATELOOP : for i in 1 to ROUNDS loop
ratatedWord := ratatedWord(0) & ratatedWord (word_size-1 downto 1);
end loop ; -- ROTATELOOP
return ratatedWord;
end ROTR;
---- SHR Function ----
variable shiftedWord: std_logic_vector(word_size-1 downto 0) := WORD;
begin
SHIFTLOOP : for i in 1 to ROUNDS loop
shiftedWord := "0" & shiftedWord (word_size-1 downto 1);
end loop ; -- SHIFTLOOP
return shiftedWord;
end SHR;
---- SHA384 HASHING Function ----
variable block_count : integer :=
get_message_blocks_count(message_padding(message));
variable mblock : std_logic_vector(block_size-1 downto 0);
variable NHash : std_logic_vector(hashed_size-1 downto 0) := IV;
begin
identifier : for i in 0 to (block_count-1) loop
mblock := get_message_block(message_padding(message),i);
NHash := NHash + F_FUNCTION(NHash,mblock);
return NHash;
end SHA384_HASHING;
---- HMAC FUNCTION -----
begin
Si := KEY xor ipad;
So := KEY xor opad;
return results2;
end HMACSHA384; -- end of function
---- GENERATE ipad VALUE ----
variable repeat_times : integer := (block_size/8);
variable final_ipad : std_logic_vector((8 * repeat_times)-1 downto 0);
variable init_ipad : std_logic_vector(7 downto 0) := "00110110";
begin
repeatloop : for i in 0 to (repeat_times-1) loop
final_ipad(((8 * (repeat_times-i))-1) downto ((8 * (repeat_times-(i+1)))))
:= init_ipad;
end loop ; -- repeatloop
return final_ipad;
end ipad_generate;
---- GENERATE opad VALUE ----
variable final_opad : std_logic_vector((8 * repeat_times)-1 downto 0);
variable init_opad : std_logic_vector(7 downto 0) := "01011100";
begin
final_opad(((8 * (repeat_times-i))-1) downto ((8 * (repeat_times-(i+1)))))
:= init_opad;
return final_opad;
end opad_generate;
end HMACSHA384_ISMAIL; --- END OF PACKAGE BODY
--///////////////////// PACKAGE BODY ENDS HERE ///////////////////////////////--
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.all;
use work.HMACSHA384_ISMAIL.all;
entity hmac_sha384 is
port ( clk,rst: in std_logic;
IV : in std_logic_vector(383 downto 0); --IV 384
KEY : in std_logic_vector(1023 downto 0); --1024
big_msg: in std_logic_vector((126*4)-1 downto 0); -- 126*4 504
hashed_code: out std_logic_vector(383 downto 0));
end entity ;
architecture sha_behaviour of hmac_sha384 is
begin
p0: process(clk) is
begin
if (rst='1') then
elsif (clk'event and clk='1') then
end if;
end process;
end architecture;
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
USE ieee.numeric_std.ALL;
entity hmac_sha384_TB is
end entity;
architecture behavioral of hmac_sha384_TB is
-- component
component hmac_sha384
port (clk,rst: in std_logic;
end component;
-- wires
signal rst : std_logic := '0';
signal clk : std_logic := '1';
signal IV : std_logic_vector(383 downto 0);
signal KEY : std_logic_vector(1023 downto 0);
signal big_msg : std_logic_vector((126*4)-1 downto 0);
signal hashed_code : std_logic_vector(383 downto 0);
begin
uut : hmac_sha384 PORT MAP (
clk => clk,
rst=> rst,
IV => IV,
KEY => KEY,
big_msg => big_msg,
hashed_code => hashed_code
IV <= x"6a09a667f3bcc908bb67ae8584"
&x"caa73b3c6ef372fe94f82ba54f53"
&x"fa5f1d36f1510e527fade682d19b0"
&x"5688c2b3e6c1f";
KEY <= x"E67FF540BA6F5C5B9FEFC68B395EC32843C4FA76355D8183146B0F7B531F2DCE810B3226EFCE3D6BE3F90F0298DBE6AF2FD41AD0B7847D8F8F0E7526CE7A85129EA6B45C3BFB9272B25CD24958C7856DF3A57A6BF748CA22D842EC5C82E09E8FF16EEB2D58DF82B9B73B452BA14D2DBF19016A21BA2E5EB5DADAFC3F921B3F11";
big_msg <= x"69736d61696c616c6d616"
&x"864695468656562616e4166697"
&x"14472617673696e746573747465"
&x"7374746573747465737474657374"
&x"746573747465737474657374";
clk <= not clk after 16.66666667 ps;
end;
