ynwia
Newbie level 1
optical to electrical converter
The circuit is to detect the onset/offset of pictures on a computer monitor (CRT or LCD). Monitor starts with a totally dark background, then a 300x300 picture appears for a few hundred milliseconds then switches to darkness, then another 300x300 picture, then dark background again...
Once the circuit detects optical change(darkness to pic, pic to darkness), it either immediately outputs a TTL pulse or changes it current status like a flipflop. The response time should be as small as possible and 1 millisecond is definitely the upper limit. (microseconds or even nanoseconds would be ideal)
I already made a simple circuit with TAOS TSL230R. It kind of works except its output is frequency (not a single pulse or constant voltage) and I have no idea of its response time. :|
The options in my mind :idea: are
1.:arrow: Go analog. For example, :idea: Photodiode->op amps->voltage regulator (7805:?: ).
2.:arrow: Digital. For example, :idea: Photodiode->op amps->microcontroller (pic 12f675:?: )
Which one do you suggest :?:
Any specific parts/circuit solutions to recommend :?:
Any input is highly appreciated.
