Failure to interface LG phone with PIC16f877, Please help!
Eng.Mohd.Salah
Newbie level 2
Newbie level 2
Hi all....
i have completed my project to send and receive messages between Mobile LG "GW300" and Pic16f877 using UART for controlling two relays. I used frequency of 8MHZ and baud rate 9600 using the program MikroC Pro. I faced big problem with my code which`s attached below. I can`t read the message, there is no action happens when i received the desired SMS "Relayxx", (where xx=Relay Number). Note that, i works on the Proteus Simulation program.
==>The Code Idea represents at when i receive SMS "Relay01", Relay no.(01) must be activated.
==> At this stage of my code just i need to read the received SMS only; ignoring the SMS_Send portion.
Does anybody has experience can help me to correct my code ??????????
Please help me casue really i need help.
my code:
Code: Select all
// LCD module connections
sbit LCD_RS at RD4_bit;
sbit LCD_EN at RD5_bit;
sbit LCD_D4 at RD0_bit;
sbit LCD_D5 at RD1_bit;
sbit LCD_D6 at RD2_bit;
sbit LCD_D7 at RD3_bit;
sbit LCD_RS_Direction at TRISD4_bit;
sbit LCD_EN_Direction at TRISD5_bit;
sbit LCD_D4_Direction at TRISD0_bit;
sbit LCD_D5_Direction at TRISD1_bit;
sbit LCD_D6_Direction at TRISD2_bit;
sbit LCD_D7_Direction at TRISD3_bit;
// End LCD module connections
void sms_read();
void sms_send();
void Get_Relay_Number();
char i=0, tmp, gsm_state=0;
char relay_no[3]; // Message that contains relay number
char relay; // Relay number
void main() {
TRISB=0;
trisd=0;
portd=0;
PORTB=0;
lcd_init();
Lcd_Cmd(_LCD_CLEAR); // Clear display
Lcd_Cmd(_LCD_CURSOR_OFF); // Cursor off
LCD_out(1,1,"Welcome");
UART1_Init(9600); // Initialize UART module at 9600 bps
Delay_ms(100); // Wait for UART module to stabilize
sms_read();
void sms_read()
UART1_Write_Text("AT\n\r");
delay_ms(500);
UART1_Write_Text("ATE0\n\r");
delay_ms(500);
UART1_Write_Text("AT+CMGF=1\n\r");
delay_ms(500);
UART1_Write_Text("AT+CMGR=1\n\r");
delay_ms(500);
while (1)
if (UART1_Data_Ready())
tmp = UART1_Read(); // get received byte
if(tmp == 'O') {
switch (gsm_state) {
case 0: {
if (tmp == 'O'){ // we have 'O', it could be "OK"
gsm_state = 1; // expecting 'K'
delay_ms(100);
break;
case 1: {
if (tmp == 'K') { // we have 'K' ->
gsm_state = 2; // expecting CR+LF
else
gsm_state = 0; // reset state machine
break;
case 2: {
if (tmp == 13) // we have 13, it could be CR+LF
gsm_state = 3; // expecting LF
else
break;
case 3: {
break;
default: { // unwanted character
break;
if(tmp=='R') {
case 0: {
if (tmp == 'R') // we have 'R'
gsm_state = 10; // expecting 'e'
break;
case 10: {
if (tmp == 'e') // we have 'e'
gsm_state = 11; // expecting 'l'
else
break;
case 11: {
if (tmp == 'l') // we have 'l'
gsm_state = 12; // expecting 'a'
else
break;
case 12: {
if (tmp == 'a') // we have 'a'
gsm_state = 13; // expecting 'y'
else
break;
case 13: {
if (tmp == 'y') { // we have 'y'
gsm_state = 14; // expecting first digit
else
break;
case 14: {
relay_no[0] = tmp; // setting first digit into array
gsm_state = 15; // expecting second digit
break;
case 15: {
relay_no[1] = tmp; // setting first digit into array
relay_no[2] = 0; // setting null
Get_Relay_Number();
break;
break;
// Converting relay number text into byte
void Get_Relay_Number(){
char rn;
if(relay_no[0] == 48){ // If first number is 0
rn = relay_no[1]-48;
return rn;
sms_send();
// SMS Send Portion
void sms_send()
int i;
/*UART1_Write_Text("AT\n\r");
delay_ms(500);
delay_ms(500); */
UART1_Write_Text("AT+CMGS=");
UART1_Write(0x22);
UART1_Write_Text("+249912677207");
UART1_Write(0x22);
UART1_Write_Text("\n\r");
delay_ms(500);
UART1_Write_Text(relay_no);
UART1_Write(26);// send ctrl + Z
The Proteus Cuircuit:
