snehan
Newbie level 2
Hello,
Please help me include a tri state buffer to call two programs in a ram single port program such that my output is, ram reads the output of daes.v only when it is enabled 1 and writes from aes.v when it is 0. software used : CADENCE
the codes are as follows.
Ram source code:
Ram testbench Code:
errors are: ncvlog -work worklib -cdslib /home/research1/17311d0615/AES/cds.lib -logfile ncvlog.log -errormax 15 -update -linedebug -status /home/research1/17311d0615/AES/128ram_tb.v
ncvlog(64): 15.20-s031: (c) Copyright 1995-2017 Cadence Design Systems, Inc.
#30 we = 1;
ncvlog: *E,EXPEND (/home/research1/17311d0615/AES/128ram_tb.v,41|0): Expecting the keyword 'end' [12.1.3(IEEE 2001)].
#10
ncvlog: *E,EXPEND (/home/research1/17311d0615/AES/128ram_tb.v,47|0): Expecting the keyword 'end' [12.1.3(IEEE 2001)].
we = 0;
ncvlog: *E,EXPLPA (/home/research1/17311d0615/AES/128ram_tb.v,52|5): expecting a left parenthesis ('(') [12.1.2][7.1(IEEE)].
cs = 1;
ncvlog: *E,EXPLPA (/home/research1/17311d0615/AES/128ram_tb.v,53|12): expecting a left parenthesis ('(') [12.1.2][7.1(IEEE)].
oe = 1;
ncvlog: *E,EXPLPA (/home/research1/17311d0615/AES/128ram_tb.v,54|12): expecting a left parenthesis ('(') [12.1.2][7.1(IEEE)].
ge = 1;
ncvlog: *E,EXPLPA (/home/research1/17311d0615/AES/128ram_tb.v,55|4): expecting a left parenthesis ('(') [12.1.2][7.1(IEEE)].
address = 128'h0;
ncvlog: *E,EXPLPA (/home/research1/17311d0615/AES/128ram_tb.v,56|9): expecting a left parenthesis ('(') [12.1.2][7.1(IEEE)].
#10 address = address + 1;
ncvlog: *E,EXPEND (/home/research1/17311d0615/AES/128ram_tb.v,59|1): Expecting the keyword 'end' [12.1.3(IEEE 2001)].
end
ncvlog: *E,EXPENM (/home/research1/17311d0615/AES/128ram_tb.v,76|2): expecting the keyword 'endmodule' [12.1(IEEE)].
ncvlog: Memory Usage - 21.3M program + 26.6M data = 47.9M total
ncvlog: CPU Usage - 0.0s system + 0.0s user = 0.0s total (0.0s, 41.7% cpu)
Ram source code:
`resetall
`timescale 1ns/100ps
module ram_sp(
clk , // Clock Input
address , // Address Input
data , // Data bi-directional
cs , // Chip Select
we , // Write Enable/Read Enable
oe // Output Enable
parameter DATA_WIDTH = 128 ;
parameter ADDR_WIDTH = 128 ;
parameter RAM_DEPTH = 1 << ADDR_WIDTH;
//--------------Input Ports-----------------------
input clk ;
input [ADDR_WIDTH-1:0] address ;
input cs ;
input we ;
input oe ;
//--------------Inout Ports-----------------------
inout [DATA_WIDTH-1:0] data ;
//--------------Internal variables----------------
reg [DATA_WIDTH-1:0] data_out ;
reg [DATA_WIDTH-1:0] mem [0:RAM_DEPTH-1];
reg oe_r;
//--------------Code Starts Here------------------
// Tri-State Buffer control
// output : When we = 0, oe = 1, cs = 1
assign data = (cs && oe && ! we) ? data_out : 128'bz;
// Memory Write Block
// Write Operation : When we = 1, cs = 1
always @ (posedge clk)
begin : MEM_WRITE
if ( cs && we )
begin
mem[address] = data;
end
end
// Memory Read Block
// Read Operation : When we = 0, oe = 1, cs = 1
begin : MEM_READ
if (cs && ! we && oe)
begin
data_out = mem[address];
oe_r = 1;
end
else begin
oe_r = 0;
end
end
endmodule
Ram testbench Code:
`resetall
module ram_sp_tb;
reg clk;
reg [127:0] address;
reg cs;
reg we;
reg oe;
wire [127:0] data;
reg [127:0] data_in;
integer l;
reg ge,en;
reg [127:0] aesin;
reg [127:0] daesin;
reg [127:0] keyin;
wire [127:0]aesout;
wire [127:0]daesout;
wire [127:0]keyout;
ram_sp uut( .clk(clk),
.address(address),
.data(data),
.cs(cs),
.we(we),
.oe(oe));
assign data = (we)? data_in : 128'bz;
initial begin
address = 128'h0;
clk = 0;
we = 0;
cs = 0;
oe = 0;
ge=0;
forever
#5 clk = ~clk;
end
begin
#30 we = 1;
cs = 1;
data_in = 128'h00;
#20
for (l=0; l<128; l=l+1)
begin
#10
data_in = data_in + 1;
end
we = 0;
cs = 1;
oe = 1;
ge = 1;
address = 128'h0;
begin
end
aes uut ( .aesin(aesin),
.keyin(keyin),
.clk(clk),
.keyout(keyout),
.aesout(aesout)
daes uut ( .daesin(daesin),
.keyin(keyin),
.clk(clk),
.keyout(keyout),
.daesout(daesout)
end
begin
tri0 aesin;
tri1 daesout;
wire ge;
toplevel g1(aesin,i, en), g3(daesout, i, en);
toplevel g2 (ge, i ,en);
end
endmodule
#30 we = 1;
#10
we = 0;
cs = 1;
oe = 1;
ge = 1;
address = 128'h0;
end
