External Interrupt in LPC1114
shanky07
Newbie level 5
Newbie level 5
Hello friends,
I am facing problem in external interrupt for lpc1114.
Here is my code =>
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
void PIOINT0_IRQHandler(void)
  uint32_t regVal;
    unsigned int i,j;
    gpioSetValue(0,2,0);
    for(i = 0 ;i < 500; i++)
        for(j = 0; j < 10000; j++);
  gpio0_counter++;
  regVal = gpioIntStatus(0, 1);
  if (regVal)
    p0_1_counter++;
    gpioIntClear(0, 1);
  return;
int main(void)
    SystemCoreClockUpdate();
    gpioInit();                    //initialize gpio clock
    gpioSetDir(0,1,0);        //set pin 0.1 as input
    gpioSetDir(0,2,1);       //set pin 0.2 as output
    GPIOSetInterrupt(0,1,0,0,1);  //set interrupt on pin 0.1
    gpioIntEnable(0,1);     //enable interrupt
    while(1);
void gpioInit(void)
  /* Enable AHB clock to the GPIO domain. */
    LPC_SYSCON->SYSAHBCLKCTRL |= SYSAHBCLKCTRL_GPIO;
  /* Set up NVIC when I/O pins are configured as external interrupts. */
  NVIC_EnableIRQ(EINT0_IRQn);
  return;
void gpioIntEnable(unsigned char portNum,unsigned char bitPos)
  switch (portNum)
    case PORT0:
                LPC_GPIO0->IE |= (0x1<<bitPos);
      break;
    case PORT1:
                LPC_GPIO1->IE |= (0x1<<bitPos);
      break;
    case PORT2:
                LPC_GPIO2->IE |= (0x1<<bitPos);
      break;
    case PORT3:
                LPC_GPIO3->IE |= (0x1<<bitPos);
      break;
    default:
      break;
  return;
While debugging above code in keil, after getting interrupt on pin 0.1 the ISR should get executed, but the code does not go in ISR. What wrong I am doing in this.
