Jan 8, 2016 #1 S Sunayana Chakradhar Member level 5 Joined Oct 24, 2014 Messages 85 Helped 2 Reputation 4 Reaction score 2 Trophy points 8 Activity points 742 Hello, I would be using an external clock in my design which may work at 24 MHz. I want to know if zynq 7020 can support this frequency?
Jan 8, 2016 #2 K K-J Advanced Member level 2 Joined Jan 26, 2012 Messages 657 Helped 308 Reputation 620 Reaction score 301 Trophy points 1,343 Activity points 7,053 Sunayana Chakradhar said: I would be using an external clock in my design which may work at 24 MHz. I want to know if zynq 7020 can support this frequency? Click to expand... Are you unable or unwilling to read the datasheet? Kevin
Jan 8, 2016 #3 ads-ee Super Moderator Staff member Joined Sep 10, 2013 Messages 7,944 Helped 1,822 Reputation 3,654 Reaction score 1,808 Trophy points 1,393 Location USA Activity points 60,207 Sunayana Chakradhar said: Hello, I would be using an external clock in my design which may work at 24 MHz. I want to know if zynq 7020 can support this frequency? Click to expand... a -1Q speed grade can handle a clock up to 464 MHz using a BUFGCTRL, 600 MHz using a BUFIO, 315 MHz using a BUFR, and 464 MHz using a BUFH. The minimum MMCM clock input frequency is 10 MHz for all speed grades. In short yes you can use 24 MHz. Go read DS187 (v1.17) November 24, 2015, Tables 67-72.
