export virtuoso library to ADS
houas18
HI,
I want to export a transistor model from virtuoso library to ADS. I need your help
thank you
Most of the models are recognized by ADS in different syntax.If you would simulate your circuit, you can use ADS simulator directly through Cadence DE.
Install ADS and define environement variables properly and start icfb then select simulator being as ADS.ADS will be your simulator in Cadence ADE...
