I want to export from HFSS to ADS , I go through this page https://www.edaboard.com/threads/220820/ but I have problem with naming the layers??
it is mentioned in there that
Go to the Advanced page and define the names of the DXF layers in your file.
How can i find the DXF layers in my design?:bang::bang:
Thank you for your help
BR
I just finally can import but the problem is the dimentions are not Ok, it is too much smaller .
what is the source of problem.
I just mention it here what I did to the others.the dimentions are not the same because both softwares should have the same dimentions. I just fing that when I import to the ADS, the default dimention in ADS changed to mil , so I just changed the dimention to mil in HFSS through unit menu and it works. if there is a error, you can just for layout.lay file , create a empty file with notepad. so at last it works. :thumbsup::thumbsup:
