DGKelectronics.com
Newbie level 3
Hey guys! I've designed a microstrip filter in ADS 2011.10 and I would like to export it to some format I could import to SolidWorks and/or PCB design software. DXF/DWG should work for both. The problem is that no matter what export format I choose the file contains nothing. The DXF file just contains the outlines of the document. If I just do "Export artwork" the resulting layout is also empty. The "More options..." dialog from the export File->Export menu has a tab "Layer", but it does not display any layers.
What do I have to do to successfully export a layout from ADS? Thanks for the help!
-Kalle Hyvönen ( https://www.dgkelectronics.com )
