Explanation of Fading and its types
Hamidzia
Member level 3
Fading
Anybody plz explain
Fading and its types.
Re: Fading
Look for this book on the eDonkey:
"The Mobile Radio Propagation Channel - Wiley&Sons"
I have it, but it's too large for uploading - 47M.
yev15 :D
Re: Fading
In general there are two sources. The first is attenuation through the path. This is more important at HF sky wave signals and does not occur noticeable on VHF local signals.
Multipath is the source of most fading. This is where the signal arrives over two or more paths and they have different lengths which produce different phases at the receiver antenna. On HF sky wave this is usually two paths. On VHF local it can be many.
The different statistics of the resulting amplitude is based on the number of paths and their signal strengths relative to each other.
Re: Fading
Do u have any idea about
Rapid wideband fading
Slow narrowband fading
Re: Fading
my lecturer's slide on small scale propagation
Fading
i know when multipath exist, fading is frequency selective. the channel can be simmulated by taped delay linear filter. you can conctrol the taps of the filter as you need.
Re: Fading
when the signal of transmiter receive in receiver from more than one way our signal may be fade. because they may eliminate the other.
