Explain Power Gating
Power gating cells are used to save power consumption.
The technique is to stop the flow of current to those circuit which are currently not in use. Thereby reducing leakage.
Don't know about structure of power gating cells. I think the widths will be more comparatively.
The gate is to avoid propagation of combinational signal through the combinational logic.
The gating could be on clock signal or on data signal.
The power gating is to switch off/on some part of the logic, which include combinational or flops elements. To restart there is to possibility, first using flop with two power consumption to preserve the contain when the power is off, the second solution, the contain is lost and you must properly "restart" with reset or reload structure.
Can you explain this above statement? Its not clear.
So, gate is used to avoid the passage of signal when not required. right?
yes...some parts may not be necessary in some application.for EX, clock is given to F/F through AND gate with Enable and clock as two inputs.When you don't need F/F to perform some action then you disable the Enable pin,by this time F/F will not get clock,So it will not make any transition, so it will not use any power.
The power gating is to save leakage power on part which could be switch off.
That's mean, you need to have some power switchs. For small node below 65nm, some std cell library provided the power switch required for that, or you need to develope your own power switch. This power switch will provided the power for the/some std cell rows.
You need to think about the power-on procedure, I means, you should need multiple power switch to be able to drive enough current, then do you power on all power switch at the same time, or one by one...?
Also this std cell library provide some flop with retention. That's mean this flop have two power supply, one to save the contain when the power switch cut the power, and the second power supply for the functional mode. Then, you need to define which module or flop need to save it contain during the power-off state, or to define a power procedure with reload state...
It is not very direct to add this feature, and that used some area, and after that, the software need to be aware, of stabillisation time when power switch is on...
Power gating simply means to cut off design using an Nmos or pmos as switches. These are basically a single nmos or pmos cells in standard cell library. The key fact to take care of in this.
a) Power gating switch should be wide enough to sink or source sufficient current during the functional mode.
b) The Vt of the power switch is usually high compared to logic gates it is trying to gate off to justify the saving in leakage.
c) As mentioned above you will need as power supply to control the power for the buffers which will turn off/on the power gates.
d) Surge current : as there will be many gates which will turn off or on due to power gates, it is important you do spice simulations to make sure the amount of current flowing through the power gate doesnt draw in-ordinate amount of current.
e) Power gating cells are put in the std cells rows in a "diamond" shape before the rest of the logic is put.
f) also one has to be carefully which power gate design interacts with non-power gated design due to floating inputs. they need to have isolation cells.
There are no power gating cells. Power Gating is a design practice
