Experts ple solve my led display problem (.at89s52 with keil C source code + proteus)
n2roy
Newbie level 3
Newbie level 3
Experts plz solve my led display problem (.at89s52 with keil C source code + proteus)
I was trying to builds a 16 X 72 led Display, but im stuck on programing. In Proteus simulation led message going smoothly but In real Mcu project its not which i expect, Led message is running but Shaken, may be its for low refresh rate. How to get more Refresh rate...
here is source code:
	   /* The current program led matrix 16x64
#include "regx52.h"
#include "font_code.h"
#define scan_led P2
//////Initial setup//////
#define so_led 8	//     multiple of 8
#define so_hang 16	//   the height of the font
#define multi so_hang+1		 //
#define cot_font 11	//   width font
#define en_run 1
typedef unsigned char uchar;
typedef unsigned int uint;
sbit rck=P3^2;
sbit srck=P3^0;
sbit ser_in=P3^1;
sbit en_hc154=P3^3;
bit run=0,en=en_run;
idata uchar display_buffer[so_hang][so_led];
idata uchar shift_buffer[so_hang];
uchar row_buffer[16]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};
uchar row_led[16]={0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15};
uchar tocdoh=0xf6,tocdol=0x00;
uchar kitu_code=0;
char row=multi;
void shift_dataled();
void test_led();
void clear_buffer();
void run_string();
void copy_datacode();
void scan_dataled_code();
void init_interrupt();
/////// Timer 0 ////////////
void isr_timer0() interrupt 1 using 1
	TH0=tocdoh,TL0=tocdol;
	if(--row==-1) row=multi-1;
	shift_dataled();
	if(row==so_hang) run=1;
/////////The main program/////
void main()
	uchar w;
	init_interrupt();
	test_led();
	clear_buffer();
	if(en==0) scan_dataled_code();
	while(1)
			if((run==1)&(en==1)){
				IE&=0xfd;
				run_string(),run=0;
				if(++w==8) copy_datacode(),w=0;
				row=so_hang;
				IE|=0x02;
//////// checking for problems led ////////////
void test_led()
	uchar i,j;
	uint t_delay=10000;
	for(i=0;i<so_hang;i++)
		for(j=0;j<so_led;j++)
			display_buffer[i][j]=0xff;
	while(--t_delay);
void clear_buffer()
	uchar i,j;
			display_buffer[i][j]=0;
///////translate data and scan LEDs////
	char i,j;
	srck=0;
	rck=0;
	if(row<so_hang){
		for(i=0;i<so_led;i++)
			for(j=0;j<8;j++){
				ser_in=display_buffer[row][i]&row_buffer[7-j];
				srck=1;
				srck=0;
		en_hc154=1;
		rck=1;
		rck=0;
		scan_led=row_led[row];
		en_hc154=0;
	uchar i;
	static uchar j;
		shift_buffer[i]=Bmp002[Bmp002[2]*i+3+j];
	if(++j==Bmp002[2]) j=0;
void run_string()
	uchar i,j;
					display_buffer[i][j]<<=1;
					if(j!=(so_led-1)) display_buffer[i][j]|=((display_buffer[i][j+1]&0x80)>>7);
					else display_buffer[i][j]|=((shift_buffer[i]&0x80)>>7);
			shift_buffer[i]<<=1;
	uchar i,j;
	for(i=0;i<so_hang;i++){
		for(j=0;j<so_led;j++){
			display_buffer[i][j]=Bmp002[Bmp002[2]*i + 3+j];
	TMOD=0x02; //timer0 mode 1 16b
	TH0=0xF8;
	TL0=0x30;
	TR0=1;
	TR1=1;
	IE=0x82;	//timer0 interrupt enable
here is schematic of that project...
Re: Experts plz solve my led display problem (.at89s52 with keil C source code + prot
You want somebody to draw the Proteus Schematic and then Compile the code and test it. Can't you zip and post your Keil project files and Proteus file?
Proteous ................
I would say its a great tool to simulate a code and its also great tool to make you fool !!!!!!
Please check your code on a real hardware module by module. Break down your codes and start it step by step. As there is no HW schamatic so its hard to detect the problem.
Regards
Engr. Amir Rashid Chishti
Design Engineer (electronics)
amir.rashid7@gmail.com
you chang code.here
TH0=0xF8;
TL0=0x30;
TR0=1;
TR1=1;
T2CON=0x00;
T2MOD=0x00;
